04 outlander vibration after axle replacement
Old Oct 6, 2013 | 05:29 AM
jak900r's Avatar
Default 04 outlander vibration after axle replacement
I just replaced the right side cv axle along with the lower control arm. During the test drive I can now feel a vibration during acceleration for a few seconds. It happens in second gear i believe. Has anyone had this or have any ideas where it would come from?
Old Oct 6, 2013 | 07:30 AM
milliesdad's Avatar
If it wasn't there before, I'd look at an out of balance axel, or possibly a tire that needs balancing.
Old Oct 6, 2013 | 09:49 AM
jak900r's Avatar
There was nothing before. I only found the bad axle while changing the belt. I just double checked everything again and nothing seems loose. I was thinking the axle, but I thought I would have a vibration even at speed not just during accelaration at 20 mph or so.
Old Oct 6, 2013 | 10:32 AM
milliesdad's Avatar
I'm betting a bad axel. Please post back what you find.
Old Oct 6, 2013 | 10:01 PM
jak900r's Avatar
I think you are correct. I did some research earlier and it seems like an out of balance axle has exactly the same symptoms as what I feel. It will probanly take me a week or so to redo it. The best recommendation is to rebuild the oem one,but the outer joint alone is 300 dollars and another 50 per boot. I will let you know when i do. Thanks for the help.
Old Nov 18, 2013 | 11:33 AM
jak900r's Avatar
Sorry it took so long but I just finally fixed the issue. I pulled my back out 3 days after and a customer help me. We determined that the aftermarket axles have a little bit of play between the inboard joint and the intermediate shaft(maybe a few thousandths just enough to create a vibration). I tried two different brands with the same result. Fortunately i kept the OEM axle and had it rebuilt. Problem solved!
Egas
Jul 6, 2014 08:50 AM
Robrote
Apr 21, 2013 09:57 PM
Diam2002
Sep 27, 2012 07:21 PM
dott
Jun 24, 2009 05:36 PM
Constm
Mar 4, 2009 06:33 AM
