07 outlander front end noise help!!
Old 06-05-2015, 12:32 PM
07xlsguy's Avatar
Originally Posted by White92VR4
Once you have the car up on jack stands, and the wheels hanging, have someone grab the tire at 3 and 9 and shake the tire back and forth, then go to 6 and 12 and do the same thing. While they are moving the tire, look at the ball joint, steering links, and bushes. Each joint should have zero play.
Yes, sway bar end links can seem tight while on the car but can be going bad.
They are so cheap and easy to replace it is almost always the first thing to try first if you can't see obvious torn ball joint boots, or the like.
Jacked up drivers side of car today, wheel hanging free. grabbed the wheel at 9 & 6 and felt a little bit of play. Took the wheel off and grabbed the brake rotor and shook the same way and noticed about a 16th to an eighth of an inch of play in the tie rod end boot, and could hear a little noise.. Wandering If any play at all is ok or not and if it has to be replaced how hard is it to do?
innieoroutie
03-14-2015 08:09 PM
tomwalshco
11-24-2014 04:28 PM
dj_jerry_p
08-26-2009 01:01 PM
Subydrift
03-10-2009 09:47 AM
jkrusa
12-19-2004 09:29 AM
Quick Reply: 07 outlander front end noise help!!
