07 OutLander Transmission service / fluid
Stick around for a while...I continually to push people to work on their own vehicles. Unfortunately, Mitsubishi stuck us on the transmission. No compatible aftermarket fluids.
However, not sure what you mean about not taking it the wrong way after you make a strawman argument. You tout how great your mechanic is, then say you will not follow his advice on the one point of this thread.
So what dealership is the one that stated you can go 95k miles?
The reason I said not to take it the wrong way is cus some people take things offensively on here and I dont want you to think Im insulting you intelligence. I've seen it on other post, so I'm just saying. What year do you have and how many miles do you have on it? I have so many miles because I live by the beach but I go to the mountains a lot for snowboarding. The outlander is great for the snow. Its great any where.
BTW, do you or anyone know the part # for the rear differential oil and how many quarters it needs?
Thanks.
I have a 2007 outlander with the jatco 6 speed transmission:
http://www.gearsmagazine.com/view.as...0-8ade815eed04
JATCO Ltd ||| 6-speed AT for medium and large FWD vehicles |||
File:Jatco JF613E.jpg - Wikimedia Commons
The transmission fluid required, as stated, is the diaqueen J2 and no other. Mitsubishi's manual for the outlander, and its service requirements, seem rather generic (for example, changing plugs at 45k miles, when exactly the same plugs are good for 120k miles in my Sienna).
I would suspect the fluid would be fine for the 95k miles suggested, but changing it earlier may prolong the life of this tranny. My Sienna, with toyota type T-IV fluid, is rated as never needing a change. Both it and the diaqueen are non-synthetic fluids. I disregard this, of course, and do a drain/fill cycle every year to swap out 40% of the fluid. I have also done a drain/fill cycle on my outlander and it's easier than an oil change.
Open the drain on the bottom of the transmission pan->catch the old fluid -> measure the quantity (3.2liters came out of mine) of old fluid -> replace the drain plug (DONT OVER-TORQUE THE PLUG!!!! THE O-RING SEALS THE PLUG. 32 INCH POUNDS SHOULD DO IT) and refill the same quantity into the dipstick tube. total cost to me was under $60 and done every year or two should keep the transmission running for the life of the car.
I have an Outlander 2008 XLS 2.4 (4B12 Eng. JATCO JF011E CVT).
JATCO Ltd ||| Belt CVT for medium FWD vehicles |||
Here in New Zealand the dealership, my mechanic, and JATCO all agree that the service interval is 90,000 - 105,000 klm or 5 years whichever comes first.
Some of the modern CVTs don't even have a dipstick, and are stated as having a lifetime fill.
Dealership quote to flush with Diaqueen CVTF-J1 NZ$350 - NZ$400.
Sounds like some of the vehicles on this forum have a conventional AT as opposed to a CVT.
Any 2007+ outlander with the V6 engine has the 6 speed jatco auto.
All V6 have a real 6 speeds transmission not a snowmobile belt device (CVT)
![Wink](https://mitsubishiforum.com/forum/images/smilies/wink.gif)
jcasaccio
06-06-2006 06:14 PM
