07 Outlander Wind Noise Fix
Old Mar 11, 2007 | 12:57 AM
biscuit's Avatar
Default RE: 07 Outlander Wind Noise Fix
The large mirrors contribute to overall noise, but that's true on all SUVs and trucks. In my case there was a definite buffetingnoise at speeds as low as 25 mph or when it was windy, this mod fixed that problem completely.
Old Mar 11, 2007 | 01:36 AM
dodo2's Avatar
"Biscuit", wheredid you get the gray foam from? Did you also use the yellow stuff? It doesn't look likeyou did from the picture, butjust asking anyway?
Old Mar 11, 2007 | 03:13 AM
biscuit's Avatar
I used the thin gray foam. I think the foam I had came from computer packaging but almost any foam will work.
Old Mar 11, 2007 | 11:19 AM
dodo2's Avatar
Thanks "Biscuit".
Old Mar 11, 2007 | 12:49 PM
antlip's Avatar
Im still confused. Is this on every 07 outlander? I dont think im hearing much more than normal wind noise.
Old Mar 11, 2007 | 03:09 PM
maharajah's Avatar
For me I had to be driving above 50mph and have a cross wind to hear the noise. It's more of a whistle that appears to be coming from the upper rear part of the driver's or passenger's window.
I did the fix myself with a little deviation from the process described here. I used a small piece of dense blue packing foam as described, however I also added a strip of window weather seal (from any hardware store) around the inside of the cover (between the tabs and the inner rib). Drives a bit quieter than my 2006 Sienna now.
ORIGINAL: antlip
Old Mar 11, 2007 | 05:59 PM
soundcolor's Avatar
Ya know, there is another fix to this problem, but it invovles a SLEDGEHAMMER.
Old Mar 11, 2007 | 07:52 PM
JMC's Avatar
JMC
It seems like anything about 40 or so it gets a little loud. So far I've just cranked the radio or I was on the phone.
Old Mar 11, 2007 | 09:55 PM
dodo2's Avatar
Is this before or after the fix?
Old Mar 12, 2007 | 01:57 AM
antlip's Avatar
ORIGINAL: soundcolor
Test that method on yours first and if its a sure fix I will do it too.
