08 Outie Rattles
Old Dec 5, 2009 | 08:32 PM
brynm's Avatar
Default 08 Outie Rattles
I know I've seen mention of it before, but I can't find it now. We have an 08 LS that has two rattles that are starting to tick me off.
1) Drivers window when partially down. If it's closed or fully down there's no noise.
2) Lower glovebox.
Does anyone have any ideas how to fix either of these?
Old Dec 6, 2009 | 05:58 AM
extinny09's Avatar
Either way....Just from the noise of the car, the roof skin rattles.Havent at least one of you guys tried to fix it? I know its a common problem...
Old Dec 6, 2009 | 10:52 AM
azjake's Avatar
I rarely if ever drive with my windows down so I can't comment on that rattle.
As far as the lower glove box, if you push on it when closed you will notice a small amount of play at the top which could cause a rattle (plastic hitting plastic) when driving over a rough surface. Considering that the box and its hinges are plastic and the box is designed to drop down (off its hinges) to give you access to the cabin air filter I don't know how you could eliminate this play. Maybe you could try glueing some rubber at the top of box where plastic meets plastic.
I don't have the rattle, or at least I've never noticed it. However I carry both the owners manual and warranty manual in it, along with other items. Most likely this provides enough weight so when I do drive over a bump or on a rough surface the weight of the items prevents the box from bouncing up and causing the rattle.
Old Dec 6, 2009 | 01:40 PM
lilaznviper's Avatar
i also have the window rattling problem
Old Dec 8, 2009 | 09:11 AM
brynm's Avatar
we get the glove box rattle if it's empty or full, doesn't seem to matter.
We also had a weird problem the other day, while driving down a straight street in town i felt a thunk. Right after the asc light came on, it wouldn't shift out of 3rd either in manual or automode and the idle was all over the place. Check engine also came on obviously. Took it in to the dealer and they figured the air filter cover had not been installed properly so the maf sensor was dirty. Cleaned it and haven't had another issue yet.
Old Dec 8, 2009 | 12:05 PM
ccernst's Avatar
I changed the air filter this summer...wow what a pain that was! I can easily see how that could not be attached firmly.
Old Dec 9, 2009 | 10:56 PM
krafty81's Avatar
I have a rattle inside the light fixture above the rear view mirror. The dealer changed it but there is still a rattle inside. Ideas?
ToysAreForBoys
Jul 30, 2014 10:49 PM
lilaznviper
Jan 30, 2010 11:24 AM
QwikEVO
Jun 24, 2009 04:16 PM
avizcarra
Oct 1, 2008 02:42 PM
larsgrafik
Jun 15, 2005 03:38 AM
