18" 9.5 Wheels
Old Apr 30, 2019 | 08:07 AM
SERPENTOR's Avatar
Default 18" 9.5 Wheels
Can the 2008 Mitsubishi Outlander XLS fit 18" wheels 9.5 wide?
Old Jul 23, 2019 | 06:24 PM
Carbon8ed's Avatar
Best info I can find is the UK C-Crosser (Citroen Outlander) is 18", 19" and 20" but all 8J with ET35mm, standard 7.5J on my 18" rims has an ET of 38mm.
I'm guessing 9.5 may be a smidge too wide, the site I got the above info listed 8J as widest. Can't do it in UK, but I think you would have to use wheel spacers?
HTH
Old Jul 31, 2019 | 05:59 AM
SERPENTOR's Avatar
Will these fit? 8.5 wide. WORK Emotion D9R – 18×8.5 47mm 5×114.3 Silver Finish (set of 4)
Old Jul 31, 2019 | 08:31 AM
Carbon8ed's Avatar
Hi, here's measurements from a US site: https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm I have assumed std EU tyre (tire) of 225/55/18 but you can put what you have and the tire you want to run.
As an aside, here are the EU spec wheels which I have on my car. Flat faces are diamond cut and look awesome: https://www.ebay.co.uk/itm/CITROEN-C...MAAOSwaNRc0q-S (OK I am biased )
If you scroll down on the US site, it highlights possible problem areas, so you could measure what you have space wise in those specific areas. I was concerned about the 'negative scrub radius' and what that could mean for road handling, but this is beyond my knowledge.
HTH
jsevinsk
Aug 14, 2022 10:36 AM
treasguy
Jan 28, 2010 07:15 PM
crow
Mar 26, 2009 10:12 AM
