2007 Outlander Cold start problem
Old Nov 18, 2018 | 02:43 PM
stanko's Avatar
Default 2007 Outlander Cold start problem
Hello everyone,
I own Outlander 2.0 DID with 190000km. Since recently, there has been a problem with the cold start of the engine so the engine can not start. The engine tries to start and immediately extinguishes and more attempts to start is necessary. When after 5-6 attempts the engine finnaly starts, then the operation of the engine varies, that is, the motor does not have constant work on the idle. At the hot start there are no problems. Has anyone had similar experiences with this problem?
Thank you,
Milos.
Old Nov 18, 2018 | 03:24 PM
SERPENTOR's Avatar
Have you checked to see if you need a new battery?
Old Nov 19, 2018 | 03:39 AM
stanko's Avatar
Yes, the battery is ok. I am confused because when the engine starts successfully the engine speed varies 1000 +-200rpm. It goes up and down for a some time.
Mikco
Mar 24, 2019 02:09 AM
mysticrythms
Mar 19, 2014 08:17 PM
1990gs2.0
1st Generation
Jan 27, 2009 11:52 AM
1990gs2.0
Jan 25, 2009 07:58 PM
hanna.karr
Jan 10, 2009 03:22 AM
