2007 outlander cooling issue
Old Aug 20, 2017 | 02:33 PM
Jayt's Avatar
Default 2007 outlander cooling issue
My fans don't seem to be coming on. I've checked the relays. I think it's not one with the fan control recall.
Old Aug 21, 2017 | 03:27 AM
Jayt's Avatar
Originally Posted by Luar
what about the fuse relay?
what about the cooling fan temperature switch?
have you wired the fan directly to the battery terminal and see if the motor works?
if not the fan then it could be the sensor for the cooling fan?
Yes I checked the fans and relay. Fuseable links too. I have not checked the cts. I have to pull it to check it and I had to buy a deep well 19mm. I'm going to modify the socket so it will fit over the connection. Will see after work today.
Jayt
Aug 20, 2017 02:11 PM
thedimon
May 23, 2014 07:27 PM
txateu
Apr 15, 2014 05:34 PM
newoutlanderfan
Oct 25, 2009 09:50 PM
jdmitsu
Sep 17, 2006 06:51 PM
