2007 Outlander Electrical Humming
Old Nov 20, 2018 | 01:36 AM
Kiwi Outlander's Avatar
Default 2007 Outlander Electrical Humming
Hi,
I have an electrical humming/whining noise from top of engine bay when key turned to AC - NOT when engine is running.
Otherwise car drives fine with no warning on dash.
Link to video:
Cheers!
Old Nov 20, 2018 | 09:36 AM
AWCAWD's Avatar
My son's Mercedes W203 made the exact same noise.The car was running fine. You might want to try to address this problem by replacing the throttle actuator control motor relay.
Check also 13B-631 in the service manual (for V6 engine) if it does not work. The link to the service manual is found in one of the sticky threads in this forum.
Old Nov 20, 2018 | 10:00 AM
ccernst's Avatar
Get a long screwdriver or other long metal rod. Put one end, handle, of the screwdriver to your ear....place the other end on the device. You will be able to "hear" the noise with much better precision. Kinda works like a stethescope
Old Nov 27, 2018 | 01:46 PM
Hi,
I replaced the throttle actuator control motor relay but noise is still there.
Doesn'treally bother me as only happens when car is in ACC.
Any other thoughts?
Old Oct 15, 2024 | 07:17 AM
peterman's Avatar
Did you ever found the problem, I have the same thing happening to my car.
Old Oct 15, 2024 | 12:13 PM
No I didn't. I have a newer outlander V6 now and it makes a similar noise ha.
Roypercy1
Feb 25, 2015 10:36 PM
JudgeLeigh
Mar 19, 2011 12:23 PM
3000gtkid
Aug 13, 2008 06:27 PM
Nubiebubie_GSX
Mar 14, 2007 07:33 PM
Keylewm
Jun 16, 2005 08:09 PM
