2007 Outlander exhaust question
Old Dec 4, 2018 | 09:10 PM
Careful's Avatar
Originally Posted by copyboy311
So I did ask the shop, and yes, that is a 3rd cat converter; however, it is not connected to an O2 sensor, so it does not relay any info to the ECU and thus will not trip any check-engine light. They insisted it would pass an emissions test as well. They never asked me if it was OK with me to cut it out. Shady? A little bit, yes. But I'd still choose that option over replacing with the factory part that cost 4 times as much. The car is 11 years old.
Well, mine has an O2 sensor in it.
If they're willing to GUARANTEE it will pass an emission test, I'd consider it. A cheap option doesn't help if you can't inspect your car. Either way, sounds super shady. I'd find a new mechanic.
Old Dec 5, 2018 | 09:01 AM
copyboy311's Avatar
Agreed, but they did guarantee it would pass. Where I live, all they do is hook up a machine to the data port. There's no visual inspection of anything. It's only an emissions test. If your car's CEL is not on, you're pretty much good to go.
Old Dec 10, 2018 | 09:51 AM
copyboy311's Avatar
Thanks!!!
Edit: "OUT OF STOCK - Unavailable until further notice" Damn it.
That carid.com exhaust part appears to be available again, as is a similar part on eBay: https://www.ebay.com/itm/2007-2009-M...1012:rk:4:pf:0
I was looking around as my front flex pipe is going to need replacement before too long.
Old May 23, 2019 | 12:36 PM
teredactle's Avatar
Looks like this is the same thing, for those here north of the wall https://www.ebay.ca/itm/163280218577
I see the link you posted includes this O ring and some bolts with springs... not sure which part is the better one to get...
Old May 23, 2019 | 09:51 PM
SERPENTOR's Avatar
Have you checked Rockauto.com
Old May 23, 2019 | 10:15 PM
teredactle's Avatar
Rockauto doesn't have the front pipe, at least not for the 2011 (mine); i had previously checked there for it but didn't remember if it had it or not.
GLudlow
Jun 8, 2017 02:03 PM
KayKay75
Jun 15, 2016 05:33 AM
mgrotel
Nov 27, 2012 10:38 AM
elerico
Jan 24, 2011 02:25 PM
9LIVEZ
Apr 16, 2009 08:11 PM
