2007 Outlander No crank
Old Sep 8, 2011 | 08:37 PM
carljr's Avatar
Default 2007 Outlander No crank
So I went the small wire on the starter while someone turned the key no power. I put power to it with my power probe and the starter turns and turns but no start. I then checked all the fuses and relays al were GOOD. next went to the trans range switch that had no power with key in start position. next on to the ignition switch that had 12.5 volts in start postion. on the wire diagram all i see between the trans switch and ignition switch is the ecm O NO... has anybody had the same problem or anything simliar if so PLEASE help thanks
Mitsiboy
Jan 17, 2005 04:28 PM
whitestallion10
Jan 6, 2005 01:20 AM
96awd
Dec 19, 2004 07:21 AM
wildwest
Jul 9, 2004 11:54 AM
Tom97rs
Nov 12, 2003 07:58 PM
