2007 Outlander Wont Come Out Of Park
Old Nov 18, 2011 | 06:00 PM
5 crawford's Avatar
Default 2007 Outlander
I had the same problem last summer. It took about 3 attempts but my local dealer figured it was the Brake Pressure Relief Valve. They fixed it and did not charge me anything. They said this has been a problem with 2007 Outlanders.
Old Jun 23, 2017 | 10:08 AM
LucaBlight's Avatar
Originally Posted by konop
I had a the same issue , you have too remove housing and on the right side of the **** ther is small contactor that You have to remove and fold back small bladge then put the contactor back that shuld fix the problem.
What housing do I need to remove? What **** is there a contactor on the right side of? What is a bladge? Are you talking at the gear selector or at the brake light actuator?
I'm having this problem and getting nowhere with my local dealership's service department, and Mitsubishi is saying there is no recall on this problem.
Old Jun 26, 2017 | 11:47 AM
binzd's Avatar
I got my brake pedal switch replaced under warranty, I think they said that in snowy/salty climates it can get corroded easily, causing the problem
Also the manual release is a small tab in a circular indent just above the shifter in the plain black plastic console, pop that out and insert a small screwdriver then the shift lock is manually released, (as if the car battery is dead it's a fail safe for towing), it will not affect anything when you release it this way, all gears and lights will function as normal (assuming you have a good battery)
Old Jun 5, 2018 | 01:00 PM
vincesofiecristy's Avatar
i have the same problem now i am worried about the safety of my family can someone please give me advice
newoutlanderfan
Dec 11, 2009 05:04 PM
ruski
May 4, 2009 09:24 PM
ccernst
Mar 16, 2009 03:48 PM
discoveraz
Mar 13, 2009 11:24 AM
mikeinfhaz
May 19, 2006 08:11 PM
