2008 Outlander Radiator Replacement
Old Feb 24, 2014 | 03:33 PM
Blagger's Avatar
Default 2008 Outlander Radiator Replacement
Hi all,
How hard is it to replace an Outlander radiator?
Slam panel off an up she goes or does it involve taking most of the front of the car off?...
Tim
Old Feb 24, 2014 | 03:58 PM
boogunoogun's Avatar
Download the service manual on the other thread and read up. I can not imagine it being that hard. Last car i did it on I had to remove the front bumper. Not hard, but time consuming
Old Apr 15, 2014 | 12:27 PM
Blagger's Avatar
Just thought I would update the thread to help others.
It is a case of taking the slam panel off then lifting the rad out, however:
1) The grill with the logo on it does detach by lifting vertically. There are some strong white 'press clips' on each corner which need levering. This is tricky without damaging the bumper paint.
2) Removal of the rad can be done from above but fitting the bottom hose onto the new one is best done from under the car. The clips for the undertray are not all the same...
3) The airbag sensor plugs are a bit odd to disconnect. I seem to remember you slide the outer shell rearwards to disconnect rather than shoving a screwdriver in...
Other than that, pretty straightforward.
Maximus99
Sep 1, 2015 03:12 AM
Lord Bahamut
Sep 21, 2012 01:04 PM
shk999
May 10, 2011 10:24 PM
Demo86286
Jul 17, 2009 03:08 PM
jdmitsu
Sep 17, 2006 06:51 PM
