2010 outlander 4wd es Fog lamps
Old Feb 9, 2011 | 10:05 AM
bobmalone's Avatar
Default 2010 outlander 4wd es Fog lamps
my suv dont have a fog lamp.but i guess it pre wired as i can see plastic covering the holes where thr lamps are to be mounted.
is it easy to install these? i cant find the switch inside the vehicle as wel.
what kind/brand of fog lamps is advisable to use in this model? will this void the warranty too if not installed by the dealer?
i need some feedbacks on this before i'll install one . i know going to the dealers will cost more money.
thanks..
Old Feb 9, 2011 | 07:58 PM
RAMON-'s Avatar
thanks..
I am guessing they may be pre wired. There is No factory switch in the Outlander to control the the lights that are not there. Easy enough to call your Mitsubishi dealer to find if you will void your warranty. Going to the dealer is going to cost you a lot of money for this installation of factory lights. If you take some time and do a search on the site you will find great information from guys that have installed factory lights, switch stalks and harnesses.
Looks like you double posted this question.
Old Feb 10, 2011 | 04:02 AM
pacman's Avatar
they are prewired for oem foglights.If you buy the kit it will come the new light control stalk with foglight switch,lights and instructions. Took me about 4 hours to install mine as you need to remove the front bumper.Hardest part was programming the computer to tell it you have foglights.
Old Feb 10, 2011 | 09:23 PM
bobmalone's Avatar
Default re: outlander oem 2010 foglights
thanks for the info. did you buy the kit from the dealer? if not ,where.
thanks
Old Feb 13, 2011 | 06:51 AM
pacman's Avatar
thanks
I got mine of e bay-dealers to expensive
jolyrgr
Aug 2, 2016 10:38 PM
bobmalone
Feb 9, 2011 10:05 AM
greengrounds
Jan 20, 2010 06:59 PM
syte
Feb 6, 2007 05:59 PM
mr_mivec
Apr 4, 2005 02:08 AM
