2010 outlander 4wd es Fog lamps
my suv dont have a fog lamp.but i guess it pre wired as i can see plastic covering the holes where thr lamps are to be mounted.
is it easy to install these? i cant find the switch inside the vehicle as wel.
what kind/brand of fog lamps is advisable to use in this model? will this void the warranty too if not installed by the dealer?
i need some feedbacks on this before i'll install one . i know going to the dealers will cost more money.
thanks..
thanks..
thanks..
thanks..
Looks like you double posted this question.
they are prewired for oem foglights.If you buy the kit it will come the new light control stalk with foglight switch,lights and instructions. Took me about 4 hours to install mine as you need to remove the front bumper.Hardest part was programming the computer to tell it you have foglights.
thanks for the info. did you buy the kit from the dealer? if not ,where.
thanks
thanks
greengrounds
Jan 20, 2010 06:59 PM
