2010 Outlander ES: add USB terminal [stock audio]
Old 12-21-2010 | 09:21 PM
Vadimus's Avatar
Originally Posted by ivanz
As for FUSE in Canada, it was available starting in the 2011 model year.
...with the same price as for 2010 model year.
Old 12-23-2010 | 12:55 AM
Fone_Fanatic's Avatar
I have an 08 outlander with the nav system and bt
Is there a software update for the FUSE system?
Old 12-23-2010 | 11:11 AM
armymen's Avatar
will like to have the USB too,
08 with the 650w system
Old 12-24-2010 | 03:37 AM
fiestataz's Avatar
Default Canadian/European Accessories & Parts
Originally Posted by Vadimus
USB input is the part of Bluetooth module. No BT means no USB. Just add BT with USB harness.
You are right, my 2010 SE has all the BT buttons ready on the steering, but BT was not installed, so my car does not have the USB input ready...
By the way, does anyone here know which Canadian site I can go buy genuine Canadian Accessories/Parts and ships to the States?
Same question for the European Accessories/Parts.
Thanks a lot
Old 12-24-2010 | 10:32 PM
ivanz's Avatar
Read this on how to physically do it (last 2 posts)
https://mitsubishiforum.com/forum/sh...952#post264952
Nobody has tried it yet, and it looks to depend on the car stereo/BT module firmware.
Old 04-23-2011 | 03:22 PM
ionicaw's Avatar
hi, i have a 2011 outlander with bluetooth pre-wired. last week i went to dealer for the BT module installation. After I got back I notice on the display if i press MODE button it goes from CD,FM1,FM2...to USB and then "U not connected" I pulled up the stereo and i found the bluetooth module and it does have a USB port but just a little bit smaller than a regular USB. what does this mean?
can i connect a special usb cable and play music via usb drive? if yes, where i can find the special cable?
thanks!
Old 04-23-2011 | 03:25 PM
armymen's Avatar
thanks!
can you send picture of the imput ?
it might be like a phone USB thing maybe ?
will be interesting if it was that easy
Old 04-24-2011 | 08:00 PM
ionicaw's Avatar
Default bT module connections
the first picture is before the bluetooth installation
the connection "thing" it looks like a regular usb but it is smaller (not as wide as the regurar USB port)
it's got 4 pins on one side (like USB) and 2 more on the other side(it might be just the metal casing on a regular usb)
I still have one more cable haging over that is not conneted and another one behind the glove box.
Attached Thumbnails 2010 Outlander ES: add USB terminal [stock audio]-0413111044d.jpg   2010 Outlander ES: add USB terminal [stock audio]-paste-013.jpg   2010 Outlander ES: add USB terminal [stock audio]-paste-017.jpg   2010 Outlander ES: add USB terminal [stock audio]-paste-018.jpg   2010 Outlander ES: add USB terminal [stock audio]-capture1.jpg
Old 04-24-2011 | 08:05 PM
armymen's Avatar
the connection "thing" it looks like a regurar usb but it is smaller (not as wide as the regurar USB port)
I still have one more calbe haging over that s not conneted and another one behind the glove box.
i will check mine tomorow interesting ,
but mine i dont get any option for USB on the system, juste normal AUX.
Old 04-24-2011 | 08:25 PM
ionicaw's Avatar
you will get USB on the display if you use steering wheell control button (MODE button)
