2011 Outlander orange headlight bulb change
Old Sep 7, 2020 | 05:07 PM
Newbaumturk's Avatar
Default 2011 Outlander orange headlight bulb change
My daughter's 2011 Outlander has the orange bulb burned out on the passenger side of the car. It isn't the turn signal, it is the small orange bulb above it closest to the hood (I guess it is considered a running light). Does the entire headlight assembly have to come out? If so, this doesn't look easy. Thanks
Old Oct 10, 2020 | 05:59 PM
kev994's Avatar
No, the bulb itself will come out, it’s on a fairly long ‘stick’ so that you can reach it, it just twists out ~1/4 turn. Hardest part is that it’s not listed on any of the parts catalogs, I checked the number on the signal light, this one was the orange bulb beside it, verified with the markings in the bulb itself.
Old Oct 10, 2020 | 06:18 PM
Thank you, I got it. I initially didn't see where it was until I jiggled the wire which moved the bulb so I could follow it. That is in a hell of a spot, I don't think a woman's hand could get in there to get a good grip on it.
Old Dec 14, 2020 | 04:29 PM
HanWee Low's Avatar
I think I have the same problem. How do you get access to the wire and eventually they bulb? Sorry I’m quite a novice in car.
Old Dec 14, 2020 | 07:02 PM
I hope I can explain this well. Next to the headlight on the inside of the fender you will find a wire. Jiggle the wire and you should see that little bulb move. You see it move, you know you have the wire. Now the hard part. This space is ridiculously tight, your typical man cannot get his hand in there, I know I couldn't. Here is the good part. I got the bulbs out (I had to replace both sides) by turning the wire itself, no way my hand could fit to get a hold of the bulb itself. The bulb doesnt take much force to get out. I got it back in the same way. It takes a little luck to get the bulb in the hole that you can't fit your hand into nor can you see the hole as you're doing it. It would be easier if you have a woman who can get her hand in there. Hope that helps.
Old Dec 15, 2020 | 12:41 AM
HanWee Low's Avatar
Thanks for the good explanation, someday I shall try this out hands on with your guide and probably not my hand 😂
Merry Christmas and happy new year to wherever you are!
rtracing
Nov 27, 2017 12:43 AM
2014outlandersport
Dec 11, 2014 03:15 PM
phs17
Jun 14, 2011 08:06 PM
muir318
Oct 17, 2010 01:03 PM
RancidSam
Jul 30, 2005 06:46 PM
