2011 Outlander V6 - crank no start / Fuse 21
Old Nov 22, 2021 | 10:05 PM
rayf01's Avatar
Default 2011 Outlander V6 - crank no start / Fuse 21
Hi all,
Our 2011 died suddenly on us the other day while driving. It will crank but won't fire and start. Taken it to a local shop and they have found it keeps blowing fuse 21 - Ignition Coil fuse however they haven't located the source of the short yet.
Has anyone had this problem before or heard of it?
Thanks,
Ray.
Old May 23, 2024 | 03:28 PM
User's Avatar
I know this has been sitting here for a few years... but I also just came across this issue and thought I'd post my find. Fuse 21 is for the 12v supply voltage to the coils. I didnt have a spark tool or anyone else to crank for me. So what I did was replace the fuse. Unplugged the harness to the rear bank. Fuse still blew. So I unplugged the 3 on front bank and re plugged the back bank. Car ran. So a short in the front side. I then resistance checked the coils. Good was like 2.7M ohms if I remember. And I had one with 0.07 ohms. So it shorted internally. That would blow the fuse soon as the efi relay was turned on. So, no code could be caught cause it couldn't run to see a misfire. And there is no monitors for coil shorting(like some toyotas have). So without that coil. Car runs on 5 cylinder. Replaced the bad coil. Hope this helps someone later. Cheers
Old Jul 2, 2024 | 04:00 PM
madmax1989's Avatar
dude im curently trying to figure out the same exact problem since 2 week on my brother's car and today i found this i hope one of the coil went bad and cause this issue so bad if it fix i will tell you for sure thanks for telling it even after so many years ! have a nice day bud !
Old Jul 5, 2024 | 09:15 AM
User's Avatar
Good luck and keep posting
Old Sep 12, 2025 | 04:05 PM
mikemccoy's Avatar
Default 2012 Fuse 21, coil coil
Same here. V6 - Metered from the load side of F21 to ground. 1.2 ohms. Unplugged the 4 easily accessible coils and reading went up to 6k ohms. Plugged them back in to isolate. Easy, except for the $265 towing fee.
dejayou2
Jun 6, 2013 07:23 PM
monsterbishi
Jun 6, 2013 07:18 PM
Christopher Pugh
Apr 1, 2012 10:10 AM
Britvalencia01
Aug 7, 2006 12:39 AM
Crich4
Apr 3, 2006 08:01 PM
