2012 O Sport Sirius radio
I posted last week about an issue I was having with getting Sirius Premiere (the old Best of XM) package added. I have finally gotten it resolved and wanted to pass along the solution in case anyone else has the issue- it is specific to the Sirius Module in the Sport 2012 Premium Radio.
To add an expanded Package to the radio it must be shut down completely by a fuse pull. It is fuse #7 in the fusebox below/left of the steering column.
First: call Sirius and modify your account, and have them send the signal to your radio- give it about 15 minutes for it to be received.
Second: Pull fuse #7 for about 5 minutes
Third: replace fuse and restart car. You should see a message "Updating" when you turn on the radio and select Sirius. After about 30 seconds th expanded lineup should be available.
Hope this helps,
Al
Hope this helps,
Al
Hope this helps,
Al
Hope this helps,
Al
Great!!
I wonder if this is the same for 2008. I'll have a look where the fuse is.
thanks!!
Could you have replied to your original thread?
https://mitsubishiforum.com/forum/mi...53/#post281017
Its a well known issue for the Outlander/RVR/Lancer/EVO. Especially if you get any channels added/deleted.
dekodan
02-05-2012 11:33 AM
rosetex
12-08-2008 06:14 PM
