2012 Outlander radio issue
Old Jul 3, 2016 | 03:52 PM
gbcooksley's Avatar
Default 2012 Outlander radio issue
I'm hoping that someone can help me troubleshoot this issue:
The display on the radio (stock) is constantly turning itself on and off. When it is off, I can't change channel except by using the steering wheel controls. It is not related to bumping etc, as it does it even in the ACC position.
I have tried removing the entire unit to check that all connections are tight, and could find nothing wrong. Put it all back together, and still the same problem.
Thanks in advance for any insight.
Old Jul 6, 2016 | 09:59 AM
The Silent Seed's Avatar
So you have two issues - Firstly, the radio turns on and off, by itself - Sorry, can't help there - but for the second issue below….
I'm not exactly sure what you mean - when it's off, it's off - so you wouldn't be able to change the channel. Lost me there.
Old Jul 6, 2016 | 10:27 AM
gbcooksley's Avatar
As noted in the original post, it is the display that turns off and on. Not the radio itself.
Old Jul 6, 2016 | 10:30 AM
It was not clear that the radio itself stays on.
Curious.
Old Jul 10, 2016 | 09:04 AM
Isophorone's Avatar
I had a similar issue with my RAV4. In summer, when the air conditioning was on, the radio would cut off when I hit a preset button. The problem was getting worse and worse. Finally, I just got a new head unit from Crutchfield.
Thankfully, I have not yet had any similar issues with my 2011 Outlander. The Mitsubishi stock radio sound is way better than the Toyota stock radio sound anyway.
Canadaj
Mar 1, 2013 05:09 PM
mr_mitsu
Aug 2, 2012 03:38 PM
lokisince89
Feb 6, 2012 08:52 PM
Rescue9
Nov 30, 2011 03:24 PM
rosetex
Dec 8, 2008 06:14 PM
