2013 Outlander Sport CVT Fluid Exchange
Old Jan 5, 2022 | 12:20 PM
mattat777's Avatar
Default 2013 Outlander Sport CVT Fluid Exchange
In my maintenance manual for the 2013 Outlander Sport, it never says that the CVT fluid needs to be changed. It only says to check the fluid. It does say to change it in the severe maintenance schedule, but not in the regular schedule. I am wondering if I should still change it anyway, or if it was designed not to be unless it starts overheating? I have no problems with anything right now.
Old Jan 5, 2022 | 02:03 PM
DibbyDibbyDJ's Avatar
Here in australia the fluid is changed every 90000kms, but if the vehicle is used in unusual conditions this is reduced to 45000kms.
Personally i think close to 45000 is the better option. The fluid is expensive, but do not use "compatible" oils. Diaqueen J4 is what it needs
Old Jan 6, 2022 | 03:28 PM
mattat777's Avatar
Did you do it yourself? The service manual says it can drain 5.39 quarts. Does it really drain that much? I have 5 but need to know if I need to buy another before doing this.
Old Jan 7, 2022 | 12:11 AM
3 1/2 litres is all you will get out. Best practice is to go for a 10 minute drive, drain it, then refill it with 3.5 litres. Then go for a 10 minute drive, drain it again and refill with another 3.5 This will ensure the convertor is flushed through and the overall oil will be cleaner
Old Jan 10, 2022 | 10:46 AM
sock puppet's Avatar
If the level is good, simply measure how much fluid drains out and refill with the same quantity.
Dave Samson
Jun 4, 2020 12:58 PM
Dave Samson
Mar 20, 2020 10:52 AM
Plex777
Feb 28, 2019 01:22 PM
rotag84
Nov 19, 2016 02:09 PM
Brendan Isaac
Mar 13, 2016 06:40 PM
