2014 outlander se..timing belt or chain?
Old Mar 1, 2014 | 11:11 PM
glock116's Avatar
Default 2014 outlander se..timing belt or chain?
Hello
Just purchased the outlander se but does it have a timing belt or chain?
2.4l engine. Also I was told I should use synthetic oil is this correct or just the dealer talking smack..
thanks
Old Mar 2, 2014 | 07:31 PM
boyette4u's Avatar
Timing chain, and do use the 0W-20 Synthetic oil Mitsu. sells. From what I've found, it is actually less expensive to buy it from the dealer than any parts store. $5-7 per quart. Tighten the drain plug to 29 plus or minus 3 ft/lbs. Turn the oil filter one complete turn after the seal becomes in contact with engine.
Old Mar 3, 2014 | 01:26 PM
ccernst's Avatar
5qt jug is all you need. WalMart sells Mobile1/Penzoil Plat for $25. Doesn't get cheaper than that unless you find special deals/rebates. As long as you use the correct weight of oil, you can use conventional. Downside to conventional is a shorter oil change interval. That interval depends on your driving habits/style.
Old Mar 3, 2014 | 03:52 PM
milliesdad's Avatar
You sure it's a chain drive and not a belt? I could swear that there is a belt, and the owners manual gives change-out mileage.
Old Mar 3, 2014 | 06:00 PM
mikeya's Avatar
Dealer told me timing chain..I asked specifically so I wouldn't have any surprises at 60-90000 miles...the 2.4 4 cylinder has a timing chain, the 3.0 V6 has a timing belt..
Old Mar 8, 2014 | 08:50 PM
boyette4u's Avatar
Yup, chain, dealer service personnel here.
Old Mar 19, 2014 | 07:19 AM
RoGuE_StreaK's Avatar
Just to confirm; does the timing chain ever need replacing or adjusting? My last two Mits were V6 with belts, so I'm unfamiliar with the whole chain thing.
Old Mar 19, 2014 | 11:17 AM
ccernst's Avatar
Chains are good for a much longer time. My '98 Ranger is still running on the original timing chain and I'm close to hitting 200k miles on it. Though I'm sure it is probably about done.
judien
Mar 9, 2018 03:41 PM
Outlander007
Dec 21, 2014 03:02 PM
thomasrivas
Jan 27, 2014 05:33 PM
skipperx
Sep 8, 2012 09:57 AM
wealderman
Feb 13, 2005 09:01 PM
