2015 Outlander Sport- Wont Start
Old Oct 3, 2015 | 06:46 PM
v_16_v's Avatar
Default 2015 Outlander Sport- Wont Start
Hello, first post in the forum.
I have a 2015 Outlander Sport and earlier today I got it to start. Then 4 hours later I tried to start it and it wont. The break pad got really stiff too.
It does have fuel. When I click the button to start it, it just makes a noise.
Any tips or things I can try to get it to start?
Old Oct 3, 2015 | 11:08 PM
caskey_b's Avatar
Does it recognize the key fob?
I know when I had my 2011, if batteries died in the fob, you could pull the key and stick it into the emergency key port (my model year was located in glove box)
I never had to do this... but this is first thing I would try.... next to check is good battery cable connections
Old Oct 4, 2015 | 01:09 PM
Lancerguy2013's Avatar
Old Oct 4, 2015 | 06:53 PM
Guyfromhe's Avatar
What kind of noise does it make? It's possible you left a light on or something that killed your battery to the point that it can't start your car...
Your brake system has a powered booster that only recharges when the engine is running that makes the pedal easy to press. If you press it more than two or three times with the car off it will get hard, once the engine fires up it will go back to normal.
Old Oct 5, 2015 | 08:01 AM
gggplaya's Avatar
It's spelled "BRAKE" FYI.
Old Oct 6, 2015 | 08:26 AM
Guyfromhe's Avatar
It suuuuure is! FIXED! It was broken so we called it the break system :P
Rapunzel41
Jul 13, 2016 12:19 PM
intense831
Jul 26, 2015 01:06 PM
sdhot5
Jun 30, 2015 02:17 AM
Admiral Beez
Jul 28, 2014 05:28 PM
c&nmiller
Mar 22, 2009 10:15 AM
