2016 Mitsubishi outlander possible crank angle sensor issue
Looking for any advice on what I can do to try and repair my outlander.
Had injector #2 blow on the engine.
Mechanic replace with new and as we drove out of the mechanics car went into limp mode, showed P0336 crank angle sensor range error.
Mechanic replaced the crank angle. Car tripped again. Turns out Mitsubishi doesn't do a crank angle relearn either when replacing the sensor. Mechanic suggested taking to an auto elec.
Took it to an auto elec who couldn't make the car fail while running idle in the garage but take it out for a drive and it trips again. Told me if he took it for a drive and needed a tow he'd bill me $600. But doesn't fail while running idle.
Auto elec brushed his hands of it saying mechanical problem not electrical.
Before seeing 3rd mechanic bought an icarsoft CR pro plus and found 5 errors
OBD2 errors
1. Fault in the AWC - C1565
2. Fault in the power steering - U0401
3. 3 Faults in the ABS - U0401 - C121C - C1707
4. Fault in the engine - P0336
Anyone able to point me in the right direction for diagnosis and possible fix?
3rd mechanic I go to will have a dyno to run it and trip the faults for $350 just to inspect but $500 in just paying to be passed off is getting old.
OBD2 errors
MattReed59
Oct 30, 2024 07:07 AM
