30K mile service
hello everyone!
i have a question regarding regular maintenance service for my outlander.
while doing oil change at my local dealership, the service guy reminded me that i need to perform the 30K mile service, which cost ~$600 and includes:
1 oil/filter change
2 tire rotation
3 air filter replacement
4 fuel injection/air induction decarbonization cleaning service
5 coolant system fluid service
6 transmission fluid service
7 maintenance inspection
i did not agree to perform the service right away and checked my maintenance manual after going back home. in the maintenance schedule listed in the manual, most items listed for 30K service are "Check XXX conditions", XXX= transaxle, oil level, coolant hose, brake etc. it does not mention anything about decarbonization or fluid service.
im wondering do you recommend these types of service that my local dealership mentioned?
many thanks!
1 oil/filter change
2 tire rotation
many thanks!
My two cents, but I'm sure there are more knowledgeable folks. I would say 1,2,3 are a given since they are regular and easy to do yourself or cheap. 4 is iffy. Most engines never see a fuel injection/carbon clean in it's life. Not to say some don't need them, it depends on driving conditions. If you have rough idle, cleaning would probably help. 5 and 6 should be done regularly, but this is also a relatively easy thing if you don't actually do a full flush. From my understanding, service departments don't do full flushes, but rather drain and fill (not the same). 7 usually doesn't mean anything as they say this for everything. Even quick lube places include this 10 minute inspection.
TL;DR, I would get 1,2,3,5,6. If you don't want to or unable to do yourself, you can get this done for much less, with most of the cost being fluid services. I don't even think I'd do more than a top up for 5 and 6 unless you are noticing strange or rough behavior. Not surprisingly, that dealer quote is dealer pricing with retail probably being 30% cheaper. I do follow the service recommendations pretty closely, but I don't change things other than oil and air filters unless they are required. I rotate tires every 7500 religiously.
600 is way too high, i was at the dealer today to buy some j4 cvt fluid and the prices werent that high, maybe in the 300 range for the 30 k service.., the fuel service bs is most likely them using their fuel cleaner product that u can purchase for like 20 bucks...i have around 33k on my sport and the tranny change was just like a oil change, the service manual does not say to do a flush, it tells them to drain and fill 5.39 l back in...the coolant which i have not done yet is probably just as easy..
Joined the forum today searching for this exact topic. Just hit 30k in our '16 Outlander and took it in to the dealership for an oil change because they sent us a coupon for $29.99. My wife was hit with the "you need the 30k mi service for $500" and when she refused it they told her they would mark it on the vehicle service report that she refused which could affect warranty work later. This is our second Outlander, first one was a 2014 & we traded it in at 50k miles for the '16 because they were running end of year sales, etc and we really liked the vehicle. This particular dealership is the most convenient to take it to for service, but every time we take it in for an oil change there is always other "highly recommended services needed" that aren't listed in the owner's manual maintenance schedule or on the recommended maintenance schedule on Mitsubishi's website.
We also own a '16 Jeep Wrangler Unlimited Back Country & 2012 Corvette Grand Sport and follow the recommended maintenance outlined in the owner's manual without any hassle for added services from those dealerships. Is this just a Mitsubishi thing, or do I need to have the transmission fluid changed at 30k even though it is not listed in the maintenance schedule? Thanks!
You can shop around and have that same servie provided elsewhere then keep records and send a copy to your mitsubishi country service center. Sometimes you can do this online.
In usa this is the FCC quote:
“The Federal Trade Commission (FTC), the nation's consumer protection agency, says no. In fact, it's illegal for a dealer to deny your warranty coverage simply because you had routine maintenance or repairs performed by someone else. Routine maintenance often includes oil changes, tire rotations, belt replacement, fluid checks and flushes, new brake pads, and inspections. Maintenance schedules vary by vehicle make, model and year; the best source of information about routine scheduled maintenance is your owner's manual.“
I understand that, I've been doing most of my own maintenance on my cars for the last 25 years. My real question is are those services the dealership is saying are required at 30k miles really needed? I don't see anything in the maintenance schedule on auto transmission fluid change nor replacing the spark plugs at 30k as the dealership is recommending. As long as I follow the stated maintenance schedule, I shouldn't have any issues with warranty work down the road. Thanks.
to the OP, why are you going to the dealership for stuff like oil changes??? unless they are right around the corner, another mechanic can do the work, use better stuff, and likely charge you less.
#4 is a load of bull.
#6 my local stealership suggested every 45k miles for my 6-speed auto. has worked great since.
#7 is a load of bull. I changed mine out at 3 years (somewhere around 75k miles) and put in Peak Global Lifetime. My radiator finally popped at 10years. I'm only going to re-fill to correct level using Peak Global Lifetime. Since I changed the fluid, I've tested the fluid with an ohm meter...never had an issue. Use a good fluid, you don't have to change it as often.
Buckmaster
Jul 27, 2012 12:01 AM
jcasaccio
Jan 5, 2006 02:07 PM
