AC power are not working
Old Oct 1, 2012 | 06:19 PM
cheech's Avatar
Default AC power are not working
i posted this in another thread i figure i would start one here. i have a problem, my AC power inlets are not working with the car off or on, i checked the front 2 and they are no go. checked the #13 fuze and its seems fine not broken no discoloring nothing. any ideas i have an apt on Wednesday with dealer cuz if it aint the fuze i'm a total loss. i heard the rear inlet is a different fuze i will check the rear inlet 2 moro.
Old Oct 1, 2012 | 06:28 PM
Claude_A's Avatar
Fusible link... all accessory 12 or 120 volts are fed by the same link ahead of the fuse box.
Old Oct 2, 2012 | 05:40 PM
cheech's Avatar
can i get to it and replace what ever easily, mind u i am not mechanically inclined but i can give it a try if its not hard. dealer apt is this Wednesday
Old Oct 2, 2012 | 06:43 PM
Claude_A's Avatar
If you are not a trained mechanic this could be a challenge.
First you have to find it in the mass of wire under the hood.
Then you still have to buy it from the dealer (it's not a standard wire).
Have a look at section GR00000400-90.pdf in directory SM of the 07 manual
located here--> 07 Outlander_XL_Manual - Minus
Old Oct 6, 2012 | 07:16 PM
cheech's Avatar
so the problem was a fuze, not # 13 but # 16 if that makes any sense. anywho cost me a total 17 bucks to get my problem, fixed
bphall74
Jul 25, 2020 12:50 PM
2001 montero
May 19, 2015 05:43 PM
pineapple12
Oct 4, 2014 09:33 AM
98supra
Jan 17, 2012 05:25 PM
robertcfi
May 14, 2010 02:24 AM
