Add aftermarket amplifier to stock audio head unit?
Great thread, helped answer some questions I had about adding an Alpine unit to replace the standard stereo on my 2010 outlander. But one problem I seem to be having is trying to find a facia that matches the dash on my outie.
The Metra and Scosche MI3015B ones seem to be plain black while my outlander has a chain mail type effect. Does anyone know where I can get one that matches the dash, preferrably in Eurpoe as I live in Ireland.
Thanks
Peter
Thanks
Peter
Suggestions on how to add aftermarket amp to stock head unit
Is it possible to add an additional amplifier to the stock audio head unit in the outlander. My dinky 140 watt stock head unit doesn't do it for me. I thought that modern amplifiers require RCA inputs. Does the stock head unit on the Outlander have RCA outputs that I can connect to an aftermarket amp? I do realize that I will want to upgrade the speakers because the cheap stock speaker may blow out. However, I do not want to replace the Head Unit if I don't have to.
If you have high level outputs and if you don't mind cutting the OEM wires and soldering on RCA connectors, you could just use the factory wiring and modify the connectors at the amplifier location to include RCA plugs for an aftermarket amp. You will want to make sure you buy an amp that can handle high level signals at its input. Remove the factory amp and mount the aftermarket amp in the same location. This would be the lowest cost, simplest approach to upgrading but it only works if you are comfortable doing the work yourself. I would never trust cutting and soldering the OEM harness to the average mobile installer at a Best Buy store or similar chain store.
If you are not comfortable cutting and modifying the OEM wiring, then a line output converter (LOC) may be the best way for you to do this.
busykb8
07-25-2012 07:59 AM
ikjadoon
07-12-2011 09:31 AM
