Aftermarket Hitch Installation - UPDATED - COMPLETE
I did not use an OE one, but the Curt one requires nothing be remove except the rear hatch where the jack is and the battery. The OE one should be the same. I have an 09. Towed 5 or 6 times now with no issues at all with the Curt harness.
Question for those who installed the OE towing harness, did you really have to undo the rear bumper skin like the instruction says to do? Because I am going to put on the OE mud flaps now and I am not sure if this means the mud flaps have to come off and I would lose the adhesive.
Sp I confirmed the mud flap does have some kind of tape along the back which extend from the lower valiance to the top of the bumper.
So I am not sure how if I can easily install the mitsu harness at a later date. If I throw a wire from the jack area does it end up going to back bumper area, or must you route things via the small grommet in the harness install instructions. I have seen a couple post mentioned they just kept the 4 pin "box" in the jack area.
Just went ahead and get under my new vehicle and applied tape over the 6 threaded holes where the hitch would install. I am still planning to install a hitch but I am not sure when I would get around to it.
The OEM hitch uses 10 bolts (2 more side facing bolts on each side on top of the 6 bottom facing bolts)
go a step beyond and get the bolts and liberally apply grease and install them. My Outie is an 09 with 24k and I needed to clean the holes with a tap. All it will take is one good salty winter to rust them up.
Pic for inspiration - looks like they do have higher capacity in UK 2.2 diesel (4400 lbs) - than the 3.0 V6 (3500 lbs)
c5055c2f.jpg?t=1301865894
e29a47bb.jpg?t=1301865929
Second of all if that thing doesn't have trailer brakes, it would be suicidal to drive an Outlander with stock brakes. Good luck going down any sort of grade for a few minutes.
The V6 gasoline engine would be better at engine braking since its higher displacement/more cylinders. Especially the 2009+ with a higher compression ratio. I would rather have safety than initially accelerating a bit faster with the diesel. The V6 has plenty of low end torque, so its not an issue like some cars with max torque at insane RPMs.
I'm quite sure the actual rating is due to laws and whatnot, and not capability. Unless the Euro Outlander has upgrades brakes, rear suspension and a jake brake
