Air filter causing check engine light
Old Jan 20, 2015 | 04:21 PM
oppositeset's Avatar
Default Air filter causing check engine light
Hey guys
I bought a new air filter and after I finished installing it, I forgot to put the electric plug right next to it. Once I started the car check engine light went on. I did put the plug back in but the light is still there.
I tried to put the old filter back but the light won't go away. Nothing else was changed in air other then this...
This is a 2011 mitsubishi outlander
thanks for your help
Old Jan 20, 2015 | 06:19 PM
ccernst's Avatar
check engine lights are stored in the computer. disconnect the battery for 5-10 min and re-connect. that should clear the alert.
Old Jan 20, 2015 | 08:51 PM
thank you
i will try that tomorrow
do i just unplug positive terminal ?
Old Jan 21, 2015 | 12:17 PM
BrianB's Avatar
Will this work on all Outlanders? I have a 2005 Outlander XLS.
Thanks
Brian
Old Jan 21, 2015 | 02:57 PM
ccernst's Avatar
it will work on all vehicles. it only clears codes out of the computer as the computer needs the battery to store them in memory. kill the power, you kill the memory, cleared codes.
the correct way would be go to a parts store, get a code reader, read the code and decide if something needs to be fixed, clear the codes with the reader.
OutlanderGT
Mar 4, 2014 04:55 PM
pgb205
Jun 4, 2009 10:40 PM
GREDDY_GST
Aug 15, 2007 06:11 PM
darknigh7th
Sep 1, 2006 09:44 PM
