Air filter question
Will a K&N air filter throw off the computer, and cause damage to engine or transmission? I have been reading reviews, have gotten a lot of differing opinions. One of the most stated is that the old carb engines did benefit for the add air flow, but that todays engines are designed to such standards that the increased air flow would throw off what the computer is "programmed" for best engine performance. Had one guy stating it would cause the tranny to shift incorrectly also, causing thousands of $$$$ in damage.
Also, lots of people were stating that the only problem they saw was that if you over oiled the filter, it would throw off the air flow sensors because of oil buildup on the sensor wire.
I would GREATLY appreciate any insight from the members of this group!
2012 Outlander 3.0L MIVEC
I think the tranny shifting incorrectly is a bunch of malarky. That would have nothing to do with air intake. I have read a lot about too much oil fouling the MAF/MAP sensor.
I would also think you'd have to change your intake/exhaust drastically to need a tune. I'm thinking something like adding a turbo/supercharger...stuff like that. a simple K&N and even a set of headers would not need a re-tune.
Increased air flow is always a benefit, especially with a turbo.....
more air - better combustion
I wouldn't put too much stock in the claim of extra mpg and power though using a k&n, if there were any gains it would be negligible. Only benefit for me when i've had them in the past is they last for the lifetime of the vehicle so pay for themselves over time. oh and they do one some models make the engine sound a bit gruntier
The K & N filter works great for me so far, No codes and no complaints. I don't give a rats *** what tranny is shifting although I have no problems with the truck now. Awesome and you don't have to buy another one is what I'm talking about..
Take a look here and you decide :
K&N Air Filter Review - Debunking the Myths (and why OEM is better)
All of that is based on ignorance. The only plausible concern is over oiling the filter and gunking up a hot wire sensor. However, most newer cars use a thermistor now, so even then it would have to be a ton of gunk to make that go bad.
K and N filters do add horsepower, but you'll usually need a Tune to see the benefit, unless you're at higher altitude and the car is having trouble making the A/F ratio due to low air density, then every little bit helps. But for the most part, you aren't going to see much gain unless you have a tune. The air restriction bottleneck is usually the engine itself, and manufacturers always design their filters to give more than enough flow for the factory tune.
gsr94trycatchit
Dec 19, 2004 07:27 AM
