bluetooth passcode
just bought a used 2011 mits outlander sport from mits dealer. the previouse owner had a passcode on his Bluetooth, and im unable to do anything with it, keeps aking for the passcode. anyway to reset passcode?
I had the same problem and found this. I had to do it a few times but it did work for me.
Turn on the system and without touching any other buttons press and hold the hangup button for 2 seconds, release it, press and hold the hangup button for 2 seconds, release it, then press and hold the hangup button for 2 seconds and release it.All this must be done within 10 seconds. In other words you must press and hold the hangup button for 2 seconds three separate times within 10 seconds. If it doesn't work, turn off the system, turn it back on and try again.. The person I spoke to said it may take several attempts to get it to work. Good Luck...
thank you so much
Thank You,!!
1. Ensure power is OFF for the radio.
2. Press and release the following buttons in this order 1 RPT, << SEEK, SEEK >>, 4>>
3. The words HFM DIAG should appear on the screen.
4. Press and release the SEL button.
5. Hold down the SEL button for a long time(about 5sec).
6. Disable the passcode
If this does not solve your issue, or you have additional questions, please feel free to contact us at 1-888-702-4100. We are available Mon-Fri, 7am-8pm CT.
