bluetooth passcode
Old Dec 11, 2013 | 10:36 PM
cas's Avatar
cas
Default bluetooth passcode
just bought a used 2011 mits outlander sport from mits dealer. the previouse owner had a passcode on his Bluetooth, and im unable to do anything with it, keeps aking for the passcode. anyway to reset passcode?
Old Dec 12, 2013 | 08:30 AM
ccernst's Avatar
most default bluetooth passcodes are either "0000" or "1234". have you tried those?
Old Dec 12, 2013 | 12:54 PM
Turbo351's Avatar
I had the same problem and found this. I had to do it a few times but it did work for me.
Turn on the system and without touching any other buttons press and hold the hangup button for 2 seconds, release it, press and hold the hangup button for 2 seconds, release it, then press and hold the hangup button for 2 seconds and release it.All this must be done within 10 seconds. In other words you must press and hold the hangup button for 2 seconds three separate times within 10 seconds. If it doesn't work, turn off the system, turn it back on and try again.. The person I spoke to said it may take several attempts to get it to work. Good Luck...
Old Jan 10, 2014 | 10:58 PM
Sterrick's Avatar
I have a 2010 Outlander xls with standard radio. I called the handsfree hotline at 888-702-4100. He told me how to reset passcode.
It was
1) with radio off press : 1 then seek left, seek right, 4. then display.
Old Nov 23, 2017 | 07:53 PM
allenmack's Avatar
Smile problem sorted
1) with radio off press : 1 then seek left, seek right, 4. then display.[/QUOTE]
OK
Had to reset my bluetooth password.
The above sorted out my problem.
Thanks for posting
Old Mar 12, 2018 | 11:41 AM
Metalbabe06's Avatar
I called the Bluetooth help hot line at 888-702-4100. I was told that the car will have one of six dealer codes.
0000
1111
1212
2121
1234
1122
I have a 2017 outlander though. But one of these codes worked for me.
Old May 7, 2021 | 02:31 AM
Bart Pitman's Avatar
0000
1111
1212
2121
1234
1122
thank you so much
Old Mar 7, 2023 | 03:25 PM
kagatori's Avatar
0000
1111
1212
2121
1234
1122
Thank You,!!
Old Jan 15, 2024 | 05:39 AM
P00chie76's Avatar
Default Reset bluetooth.
This worked for me: Standard non touchscreen radio.
1. Ensure power is OFF for the radio.
2. Press and release the following buttons in this order 1 RPT, << SEEK, SEEK >>, 4>>
3. The words HFM DIAG should appear on the screen.
4. Press and release the SEL button.
5. Hold down the SEL button for a long time(about 5sec).
6. Disable the passcode
If this does not solve your issue, or you have additional questions, please feel free to contact us at 1-888-702-4100. We are available Mon-Fri, 7am-8pm CT.
fr8dog69
Nov 28, 2023 09:29 PM
euler21
Aug 30, 2011 10:32 AM
mrtn
Jul 16, 2007 03:09 PM
stuart100
Apr 19, 2007 09:48 AM
drh
Nov 15, 2006 07:25 PM
