Brake Fluid Change
Old Sep 20, 2014 | 06:34 PM
Isophorone's Avatar
Default Brake Fluid Change
Hi everyone!
I have a couple of basic questions about changing brake fluid on my 2011 Outlander ES. Right now it has about 47,000 miles on it, and so far all I've had to do is get the rotors machined.
1) Exactly which place is the valve to open to drain out the brake fluid? I looked in the manual that was posted online and couldn't tell. Can someone post a drawing or picture?
2) Does the car have to be on ramps or jack stands to do this job?
Thanks for your help!
Old Sep 21, 2014 | 12:56 PM
Akzle's Avatar
1) get a friend who has done brakes before. Fluid nipples usually on calipers.
2) not essential, but you want the wheel youre bleeding off.
Old Sep 21, 2014 | 06:42 PM
Isophorone's Avatar
Thanks much! I'll ask my mechanically-inclined neighbor.
Pardon my lack of familiarity, but why do you need the wheel off if the nipple is accessible? Is it because of the corrosivity of the brake fluid that comes out, or is it just more accessible that way?
Old Sep 22, 2014 | 02:44 AM
Akzle's Avatar
can you get a ~10mm spanner on to the nipple with the wheel on? if you have big gapped mag wheels you might, then go for it.
if you're spilling brake fluid then you're doing something carelessly.
more likely it will be more comfortable to take the wheels off as you do it.
google sucks, but perhaps read this:
Bleeding Instructions | HEL Performance
newoutlanderfan
May 27, 2013 10:47 AM
atasic
13
May 7, 2007 07:59 PM
djk1
28
Sep 22, 2006 01:45 PM
Nubiebubie_GSX
Jun 24, 2006 11:25 PM
jcasaccio
Jun 6, 2006 06:14 PM
