Brake pads
Old Oct 13, 2011 | 12:12 PM
ruski's Avatar
Default Brake pads
Does anyone know whether changing brake pads is a do-it-yourself job?
Old Oct 13, 2011 | 03:02 PM
ccernst's Avatar
it is a super easy DIY. The only tricky part is to remember you may need to siphon some fluid out by the time you get to the third wheel.
jack the car up
take wheel off
take one caliper pin out, furthest away from brake line.
caliper will then rotate enough to get old pads out.
use channel-lock pliers to compress the piston back into the caliper (fluid will go back into the resivoir...watch the fluid level at this point)
pop new pads in
rotate caliper back down onto rotor
re-grease caliper pin with the $1 packet of caliper grease you bought earlier
tighten caliper pin...you may want to get some locktite. I've never needed to use locktite, but some use it.
throw your wheel back on.
start up the engine after you've done all 4 and pump the brakes to push the pistons back where they should be...and keep an eye on the fluid level while doing so.
you are done.
Old Oct 13, 2011 | 09:53 PM
ruski's Avatar
So I need to go procure a floor jack...
Of course I have done wheel rotations using my emergency jack, but I think it is getting tired.
I already have jack stands. Are there good spots for jack stands?
Old Apr 18, 2012 | 03:15 PM
xOutlanderFiendx's Avatar
jack the car up
take wheel off
pop new pads in
you are done.
do you have any pictures or diagrams that could help with this?
also i have an 09 outlander, can you replace the breaks better ones?
Old Apr 18, 2012 | 11:22 PM
ruski's Avatar
I actually did my rear pads last Sunday. Very easy.
I did the fronts back in December 2011. Very easy too. The fronts were worn out before 50K miles.
The rears still had some thickness in them at 56K miles.
Old Apr 19, 2012 | 12:39 PM
i wanted to know if its possible to remove and replace the whole brake system.. is it a possible DIY?
Old Apr 19, 2012 | 08:30 PM
ccernst's Avatar
it all depends on your ability to turn a wrench. it also depends on "whole brake system". if you mean just replacing the calipers, if you can turn a wrench and bleed a brake system....it is easy.
bhamvett
Apr 8, 2008 01:10 PM
Smola
Jun 13, 2006 09:39 AM
Takumi
Nov 1, 2005 04:22 PM
dolfans
May 19, 2004 12:14 AM
Jacoby
Nov 12, 2003 11:14 AM
