Bubbles on ATF dipstick?
Old May 17, 2016 | 09:05 PM
07xlsguy's Avatar
Default Bubbles on ATF dipstick?
I changed my ATF fluid a while back [havoline dextron VI synthetic multi vehicle] and noticed today that the dipstick was reading high by about an inch.... removed atf drain bolt, let about 3/4 quart of fluid out, tightened drain bolt and level was good...
After driving I checked the fluid level and noticed lots of little bubbles on the dipstick. Obviously air was introduced while fluid was draining out..?.. Is this an issue of any concern?
Old May 18, 2016 | 07:25 AM
ccernst's Avatar
You may have taken too much out and the tranny may be whipping it to a froth. Wait till it is cold and check again....dipstick has hot/cold marks.
Old May 18, 2016 | 07:54 AM
07xlsguy's Avatar
JUST TO CHECK... You DO check the level with the car running?
Old May 19, 2016 | 07:39 AM
ccernst's Avatar
Yeah...but with the possibility of the fluid frothing, I'd check before starting...just to have an idea.
newoutlanderfan
Jul 2, 2013 09:39 PM
josepi
Aug 27, 2011 07:56 PM
Phenom
Aug 30, 2010 10:37 PM
royg
Oct 27, 2006 02:13 AM
chrisacain
May 29, 2005 10:31 PM
