Burning Audio CD to MMCS Tags
Old Oct 12, 2009 | 07:56 PM
red123's Avatar
Default Burning Audio CD to MMCS Tags
So I was burning a audio cd from my mp3 collection. When I insert the disc to the MMCS Drive, the title songs doesn't show up correctly. It started to record but I stopped it b/c of the title being so effed up.
Track 1 lists as V instead of the actual song title, next is B, random letters and so on.
Is there a problem?
________
BUY CANNABIS SEEDS
Old Oct 12, 2009 | 09:28 PM
rip14's Avatar
Check the ID3 info on the MP3 and see if its all correct.
What program are you using to burn?
Old Oct 13, 2009 | 07:07 PM
ccernst's Avatar
are you burning your mp3 files as mp3 files on the disk or as CD-Audio? I agree with RIP, check the ID3 tags, since that is what your radio is reading. I don't have MMCS, but the regular radio and it reads my ID3 tags just fine.
Old Nov 15, 2018 | 11:12 PM
reprak1969's Avatar
Default MP3 Titles
I had the same issue with the MMCS (2007 Pajero) and this solved it:
1/Use Nero or Roxio or in Linux Brasero for burning
2/ Ensure that there is no numbers at the beginning of the song tile. Example: "01-Like a Virgin Madonna" , 02-Lucky Start Madonna" etc. If the numbers are there, remove them
3/ Use only CD-R. (You can burn plenty of MP3 on 600MGB disc)
4/ Ensure you chose "finalize disc" (no other files can be added after burning"
5/ Burn at at slowest speed minimum (I used 8x and worked fine for me)
That is it. After I did all of these, the titles were shown.
Hope that works for you guys.
Happy driving!
hotponyshoes
Mar 16, 2012 05:53 PM
hotponyshoes
Sep 22, 2010 12:26 PM
monterodude
Dec 18, 2006 02:33 AM
tidus10
Mar 10, 2006 06:41 PM
shivan15
Oct 19, 2005 03:27 PM
