bypass for f940bt ?
Old Oct 19, 2012 | 10:35 AM
raymond's Avatar
Default bypass for f940bt ?
hello
bypass is possible for avicf940bt?
to see a dvd without activating the parking brake
the Vodeo youtube does that x940bt and I do not understand very well (bad video not very well explained)
thanks
Old Oct 19, 2012 | 05:02 PM
tcp's Avatar
tcp
Looks like the european f940bt just requires you to ground the parking brake wire. North american x940bt units need to ground it through a relay that is switched by the accessory trigger (usually a blue) wire.
http://www.talkaudio.co.uk/ipb/index...dbrake-bypass/
Old Oct 19, 2012 | 06:40 PM
raymond's Avatar
ok, green wire to ground, understand, thank you.
which has a link to a picture (diagram) (post7)
Mitsubishi Outlander-12 Nav install wire question - Page 2 - Mitsubishi Forum - Mitsubishi Enthusiast Forums
largest on the schema that is in this post I do not see what is written.
I board this connector also , for my avicF940BT.
CTHMT01 Mitsubishi Outlander Steering Control Reverse Sensor Replacement Interface
I wanted to connect my pioneer, without making a bad connection
thanks
fireboy153
Oct 7, 2013 04:46 PM
fireboy153
Feb 24, 2008 04:10 PM
DaniDunn
Sep 20, 2005 11:21 AM
Tom Q
Jun 9, 2005 12:06 PM
outlancer
May 12, 2005 11:52 PM
