A/c issue
#31
I looked this AM... I couldn't actaully see the fans I might need a flashlight..
It seemed like the fan was in the middle from where the airflow was and the sound...
I'll try and look better when I'm not in a rush to get to work....
The fan definitely cycled on and off with the A/C compressor.
#32
OK I just checked...
There are 2 fans..
The one closest to the driver side has a blue connector 4 wire and the one on the passenger side has a 4 wire grey connector.
Car was sitting in hot garage for a few hours, pulled it out and looked in with a flashlight. Ext temp sensor reading 28c did all this testing within 5 minutes of starting it.
Climate system off -> Both fans stopped
Climate system on but near correct temp -> Both fans running at low speed barely audible.
Climate system on set to max (15 or whatever) -> Both fans screaming
It looks like they may be possibly controlled separately but I don't have a wiring diagram.. They could be connected together somewhere down the line. I couldn't find a situation where they ran at different speeds or one stopped while the other was running though.
Might want to pull that connector and re-seat it.. I had a power headlight that seemed dead and it was just the connector wasn't properly engaged.
I saw a video (on a lancer not sure what year) but the cooling fan controller was bolted to the back of the fans (little black box) and it only had 3 wires from the PCM (+, GND and control) so I don't even think the system can control them separately unless the fan controller is doing some kind of jiggerypokery or they changed the design for the newer cars.
There are 2 fans..
