Canadian Outlander SE V6 awc or s-awc
Old Aug 30, 2017 | 12:55 PM
daveddiamond's Avatar
Default Canadian Outlander SE V6 awc or s-awc
Hi All,
I've been unable to find this info anywhere on line. Trying to find out if my Canadian 2014 Outlander SE 3.0l V6 has s-awc or just awc. I ask because according to my VIN in space 5 & 6. (Make, Car Line & Series) its listed as Z3 which according to the decoder means SE S-AWC,
D2 = Mitsubishi Outlander ES (FWD)
D3 = Mitsubishi Outlander SE (FWD)
Z2 = Mitsubishi Outlander ES (AWC) (Canada only)
Z3 = Mitsubishi Outlander SE (S−AWC)
Z4 = Mitsubishi Outlander GT (S−AWC)
However I don't appear to have the 4wd options such as snow mode, etc that comes with s-awc. In Canada it would seem you need the GT to get s-awc. Can you get the 3.0 V6 in the US with either awc or s-awc?
Old Aug 31, 2017 | 04:04 AM
Lancerguy2013's Avatar
I'm pretty sure if your vehicle does not have the S-AWC badge on the tailgate its just AWC
Mine is a 2015 with the 2.4 4 Cyl./...I have a badge on the rear that says AWC..
Old Aug 31, 2017 | 08:40 AM
Correct, the badge is awc. Just odd the VIN indicates otherwise. Wonder if the system is in place but defeated some how from the factory?
Old Aug 31, 2017 | 07:14 PM
When you press the 4WD switch in the center console the display on my vehicle shows 4WD-E( essentially 2 WD)...nothing on the display second press...thats 4WD ON...and lastly.. LOCK...in Orange on the display..Thats it for AWC AFAIK
Old Apr 27, 2018 | 07:04 PM
Brentskii's Avatar
If you do have it, it will say s-awc by your dial to change the setting by your gear shifter and also in the little display for the information. But you need to select the s-awc option by pressing the info button to see the system at work. If you don't have that then you don't have s-awc. Btw mine is a 2010 xls with s-awc and no badge but I ended up buying the badge and putting it on mine. It's only 2010-2013 xls and gt that have s-awc and after that only the gt since they don't make xls anymore.
bender031177
Jul 17, 2023 11:46 PM
Elisha
Oct 3, 2012 06:27 PM
baboSo
May 18, 2010 12:31 PM
ivanz
Jan 22, 2010 09:37 PM
ShortyRider
Feb 2, 2009 05:10 PM
