can't turn off ASC
Old Dec 27, 2015 | 06:57 PM
newoutlanderfan's Avatar
Default can't turn off ASC
Hey all
Got a2009 4wd outie. Just realized today that if I hold in the asc button which should turn off the asc, nothing happens. Usually, you hold the button for 5 second and a asc off notice shows up on the dash. Now nothing happens.
I did have one asc off error last year but that seemed to go away and things were good after that. I still get the car with the skid marks in the yellow display when I'm slipping in snow which I am assuming wouldn't come on if the asc was off? Or would it?
Any thoughts? I read one post where they dealer unplugged it by mistake when installing a heated seat.... Coincidentally I had a seat replaced. I wonder if that was it.
Anyone else have any issues? I just want to make sure it is still working.
Thanks
Dave
Old Dec 27, 2015 | 10:35 PM
Guyfromhe's Avatar
When you start the car you should see the ASC light come on during the light test if it's still properly enabled.
If the computer was disconnected you would get a service ASC message on your dash.
Holding the button down SHOULD turn it off. It's possible if they were fiddling in there they could have unplugged the button.
Old Dec 28, 2015 | 02:34 AM
It definitely doesn't turn off.. I held the thing in for 30 seconds.
Stupid question but is it hard to check to see if the button is unplugged? I'm sure if I take it to the dealer, they'll find a way to gouge me.
How long should it take to diagnose that and plug it back in?
Thanks
Old Dec 28, 2015 | 05:26 AM
It also doesn't come up when starting the car.. But I never really noticed if it ever did or not
Old Dec 28, 2015 | 10:11 AM
Guyfromhe's Avatar
Pretty sure there should be a light for it (not the screen in the middle) but there is a little indicator light at the top or something like the brake light and the check engine light. Next time I'm out there I'll check mine.
Old Dec 28, 2015 | 07:00 PM
Guyfromhe's Avatar
Nope, just checked, it doesn't look like there is a physical light... It just shows up in the middle display ASC OFF.
I'd say if it's still working it's probably just the switch.
Old Dec 28, 2015 | 10:42 PM
stanza75's Avatar
Got the same problem here with my 2008 outlander. Haven't take it to a dealer yet for diagnosis. Planning to do it by the end of next month. If you get a chance to fix yours before me, gimme the update
Old Dec 28, 2015 | 11:08 PM
Guyfromhe's Avatar
Though when I screwed up my ETACS settings the ASC OFF thing showed up on the center display and wouldn't clear, so I would have to guess the computer is detected and communicating correctly.
I don't think there's any way to interact with that system directly other than the one button though..
Old Dec 29, 2015 | 12:20 PM
Thanks for checking. I think everything works, except for the button. They want a half hour labor to check it. Anyone have any idea how to check the button yourself?
Thanks again
Old Dec 29, 2015 | 02:06 PM
Guyfromhe's Avatar
If you know how to pop that panel (check the service manual) it probably only has 2 wires, check to make sure it's connected and then check continuity... That should probably give you an answer...
If you can't take the panel out yourself let the stealer do it, or just ignore it... You probably won't need to turn off ASC anyway.
edurbeck
Jul 13, 2012 02:59 PM
07outty
Dec 12, 2008 11:24 AM
itoig
Oct 25, 2008 06:04 PM
cybergoogle
May 31, 2008 01:38 PM
dornstar
May 22, 2006 04:58 PM
