Changing the 2WD-4WD Switch on Outlander
Old Feb 1, 2019 | 10:49 AM
SERPENTOR's Avatar
Default Changing the 2WD-4WD Switch on Outlander
Has anyone ever changed the round switch that is used to change from 2WD-4WD? This is for a 2008 Mitsubishi Outlander XLS V6, does it require and special tools or wiring? Is it just a pull out and replace job?
https://www.mitsubishipartswarehouse.com/oem-parts/mitsubishi-switch-8604a008/?c=Zz1ib2R5JnM9Y2x1c3Rlci1hbmQtc3dpdGNoZXMmaT02MjU 1MzgwNSZyPWxheWVyXzExJmE9bWl0c3ViaXNoaSZvPW91dGxhb mRlciZ5PTIwMDgmdD14bHMmZT0zLTBsLXY2LWdhcw%3D%3D
Old Feb 1, 2019 | 01:08 PM
AWCAWD's Avatar
FYI, please find the attached relevant pages from the service manual. Before you change your existing unit you might want to test whether it needs to be replaced at all.
File Type: pdf
File Type: pdf
Old Feb 1, 2019 | 01:48 PM
SERPENTOR's Avatar
The reason I want to change it is because a piece cracked off the top of the drive selector **** it is purely cosmetic.
Dsmoovy
Nov 21, 2011 03:00 PM
Incisen
Jul 18, 2011 08:48 AM
MooF
Sep 11, 2010 11:12 PM
thehintons06
Jan 15, 2008 04:10 PM
jcasaccio
Mar 23, 2006 12:33 PM
