Code P2252 on a Outlander
Old Jan 22, 2016 | 11:41 PM
santfe's Avatar
Default Code P2252 on a Outlander
My daughter ran over a plastic bucket on the freeway, now her check engine light is on. Attached it to reader and the following message shows up. What does it mean?
Old Jan 23, 2016 | 11:34 AM
SERPENTOR's Avatar
Talking Googled it
Attachment 3757
Mitsubishi Outlander P2252 Engine Trouble Code - Mitsubishi Outlander P2252 OBD-II Diagnostic Powertrain (P) Trouble Code For Mitsubishi Outlander | EngineTroubleCode.com
Old Jan 24, 2016 | 12:51 PM
santfe's Avatar
Default Thanks
I had the vehicle checked, something broken by or on the muffler. More than likely the sensor. Thanks
Old Jan 24, 2016 | 04:36 PM
SERPENTOR's Avatar
Your welcome!
Old Jan 24, 2016 | 05:17 PM
Guyfromhe's Avatar
I believe there's an oxygen sensor at the catalytic converter so the car can judge how well it's doing as far as emissions go and adjust fuel accordingly. The sensor or wiring is probably what broke.
Old Jan 25, 2016 | 08:55 AM
binzd's Avatar
the negative side of the O2 sensor is how the ECM judges if the sensor is doing allright, you may be able to get under there with a solder iron if the wire is clipped, but if it tore out of the sensor, start looking online for bank one sensor one, which is most likely upstream of the cat, on CA emissions PZEV I have 6 or 7 of the damn things
Old Jan 26, 2016 | 09:18 PM
santfe's Avatar
Thank you all, yes the sensor is broken. Price for sensor $150-300+, now to find one.
pigman
Aug 19, 2016 04:47 PM
catacami
Jul 21, 2013 12:30 AM
Captain_Crusty
Feb 13, 2012 04:25 PM
shane walker
Sep 24, 2010 04:35 PM
Le@r
Aug 15, 2010 01:38 PM
