Constant buzzing coming from boot area
Old Jan 10, 2019 | 04:14 AM
Ajhowarth's Avatar
Default Constant buzzing coming from boot area
Please help. My daughters ASX has a constant high pitche buzzing sound emanating from the hatchback area. The noise is fairly loud and is continuous 24/7
Old Jan 10, 2019 | 09:30 AM
AWCAWD's Avatar
We are more than happy to help if you are willing to describe the noise in more detail. Meanwhile please check out this thread . Post #37 describes the solution that solved my problem but you have to provide a much more detailed diagnosis if your noise is different. Is the noise speed or rpm, or road surface etc.dependent? Do you have a subwoofer installed in the boot/trunk (OEM or afermarket)? 24/7 means to me that you may hear it even if the car is stationary. Is it correct? Please take the time and provide as much information as possible.
Old Jan 10, 2019 | 10:15 AM
Ajhowarth's Avatar
The noise is there all the time. When it's parked, engine not running and is a continuous whine. Noise continues when engine is running. Her battery went flat not long ago and the chap who tried to jump start it with cables put them on the opposite terminals. She has since had a new battery fitted. Hope this helps
Old Jan 10, 2019 | 11:13 AM
AWCAWD's Avatar
OK, so now we know a lot more and your situation could be lot worse than I thought. The inverted polarity jump start must have fried some electronics. Now we know what is the cause of your problem but his issue cannot be solved or even diagnosed over the internet especially because it is audible even when the car is parked when all electronics are presumably shut down. You have to take the car to a knowledgeable (certified) car electrician and have him check your electrical circuits. ECUs (one or more) are the most likely candidates. We would only be able to guess and guesses that you need the least in this situation.
As a first step I would check all the fuses and relays in the engine bay and in the passenger compartment. You should try to pin-point the the exact location of the noise. It should not be difficult since the noise is present all the time, so you can do it while the car is parked.
Good luck!.
Old Jan 10, 2019 | 03:54 PM
Ajhowarth's Avatar
Many thanks for your answer. You're very kind. I shall break the news gently to my daughter.
NewAge Tony
Aug 31, 2018 09:10 PM
NewAge Tony
Aug 31, 2018 09:03 PM
robtheviking
Jul 20, 2018 10:20 AM
Tomo1971
Apr 16, 2011 05:11 AM
tul813
Dec 11, 2007 06:09 PM
