Creaking Noise coming from the right A pillar or dash area
Old Mar 16, 2015 | 01:18 PM
Corbul's Avatar
Default Creaking Noise coming from the right A pillar or dash area
Hello everyone. Starting 2 moths ago a weird noise started to annoy me and I can't figure out where it is coming from.
It sounds like a creaking / cracking noise and it appears to be coming from inside the car around the passenger side A pillar or dash area. It is loud and can be clearly heard even with the engine revving. It ONLY happens when I am accelerating, breaking or when I go over some bumps with the right wheel (chassis torquing maybe). My suspicion is there is something loose and it is moving since it is happening when accelerating or breaking.
I initially thought it comes from the glove compartments area, but I have removed everything inside + the covers and the noise is still there. Also with the glove compartments covers removed I had access to all the wires under the glove compartment and made sure nothing is loose. Sadly, I couldn't find the source, the creaking / cracking noise is still there and it is driving me nuts, especially in the city.
Does anyone have any idea what is going on?
Old Mar 17, 2015 | 08:17 AM
kazlas's Avatar
i have similar noise, i believe its coming from the shock or the spring, where spring touches the rubber. I checked all front end, everything looked solid, sprayed little wd-40 on the spring, i think it got little better.
Old Mar 26, 2015 | 07:23 PM
Corbul's Avatar
I managed to get everything repaired at the dealership. It turned out to be a pin close to the firewall that was holding and aligning the dash. The small noise apparently came from wear and tear over the years and a small gap appeared. The solution was to wrap the pin in rubber. The noise is now gone and the repair was about $150.
Lukin
Jul 26, 2011 07:42 AM
Hawk1018
Oct 6, 2010 02:39 PM
fizzwhiz1
Aug 2, 2010 11:54 PM
kaiba408
Jan 28, 2007 01:54 AM
Heartzz_on_fire
Feb 12, 2005 02:56 PM
