Dead display for radio
Old May 22, 2013 | 07:42 PM
ivanz's Avatar
Originally Posted by mprojekt
Do you know if it's possible to replace *just* the display? My Outie came with MMCS, so I don't know what the back side of the radio cd panel assembly looks like.
It'd be great if folks could pull the LED display module itself and swap it out with one that works. Or is that sucker a permanent part of the panel assembly?
I realize that this is probably a "nice idea" at best but it can't hurt to think along those lines.
the MMCS comes as one single part. You would probably have to do a bunch of soldering work to replace the LCD only. Whereas the faceplate on the non-NAV is just plastic and a PCB separate from the unit itself.
Old May 22, 2013 | 09:43 PM
mprojekt's Avatar
Oop. I didn't clarify. I was referring specifically to the radio CD head unit and the LED display in the panel assembly, in relation to dissecting the panel assembly to swap in a functioning LED display.
I noticed right away that the MMCS is an integrated unit the day after I got my Outie and had a chance to take the dashboard apart. <cough> I couldn't help myself. New toy, must tinker, ya?
I definitely need to be more caffeinated after I get home from the office, when I'm trying to communicate my thoughts clearly at night.
Old May 23, 2013 | 06:20 AM
tfreiesleben's Avatar
Default It is a radio with CD and not the NAV-version
To clarify any misunderstandings. I'm refers to a NON-nav version, where the unit is hidden behind the dashboard. It is the display with orange digits there seems to be broken together with the buttons in the dashboard front.
Old May 23, 2013 | 10:10 AM
mprojekt's Avatar
If the radio is working just fine, as far as you can tell, then yes, you only need to replace the panel assembly.
Found one on eBay, btw:
Mitsubishi Outlander A V Equipment Recvr Am FM Stereo CD Player Dash MTD | eBay
But you'll want to contact the seller to find out if they are selling the radio cd head unit by itself, the panel by itself, or the entire kit and caboodle.
FYI, brand-new panel assemblies cost about $630 USD, so check eBay before you resort to getting one from a dealership.
Old Aug 31, 2021 | 12:06 AM
Grigglespot's Avatar
Is there likely to be any connection, fuse wise, between the display and the background lighting of speedo n tacho. Was just wondering as that doesn't seem to be working either
Paulaqpie
Oct 23, 2016 06:36 AM
aksunamoon
Jan 25, 2014 10:33 AM
KF97diamonte
May 5, 2010 01:38 PM
CO 3000GT
Jun 11, 2006 02:27 PM
bcolins
Aug 15, 2005 12:52 PM
