Detailed Rear Camera Installation
Old Oct 23, 2008 | 04:02 PM
  #91
mitsupartsman.com's Avatar
Default RE: Detailed Rear Camera Installation
There are only clips holding the interior panels on. The outside finish panel is held on by some nuts on the inside.
Old Oct 24, 2008 | 09:22 AM
  #92
LIComputerGuy's Avatar
Thank you for your quick response!
Old Nov 17, 2008 | 04:04 PM
  #93
ruski's Avatar
ORIGINAL: boriparamivida
I was able to trace where the wire goes after it comes out of the MMCS, I will have pictures up soon, but after it comes out of the MMCS, all the wires trace over to the left side connector {the three connectors which are attached to the adapter that holds the MMCS, right before it goes into the next harness}, after the wires reach there, they terminate, I used a multimeter to find the correct routing of wires, I will have the exact pins that they land at soon.
So instead of cutting these wires, would it be better to just splice the camera cable's wires into these?
Old Nov 17, 2008 | 04:33 PM
  #94
there is now a wire harness whichs plugs into the back of the mmcs and will run directly to the camera. check this link
http://www.trademotion.com/partlocat...egoryID=141766
Old Nov 17, 2008 | 05:43 PM
  #95
ruski's Avatar
Thanks. So I can unplug the OEM connector and just leave it hanging?
Old Nov 17, 2008 | 05:47 PM
  #96
yes you can......no more cuttingthe wire harness
Old Nov 23, 2008 | 08:19 AM
  #97
chuwey25's Avatar
Thats brilliant (the wiring loom i mean!) - can this then be used with the Pioneer camera that is being recommended, or does it mean you have to get the official Mitsi one that is listed? (indeed, is the official one any good?)
Old Dec 6, 2008 | 12:30 PM
  #98
aad's Avatar
aad
Is there any need to make the MMCS automatically show the rear camera picture when put inrear (gear) ??
Or does it all go by itself?
Old Dec 6, 2008 | 12:56 PM
  #99
20Outlander07's Avatar
I haven't installed one yet, but I remember reading in this post that it does it all by itself and immediately when it is put into reverse (e.g., don't have to wait for the initialization screen to go away).
I hope to install a camera soon. I was thinking about getting the Kenwood camera since it got good reviews for nighttime illumination and the Pioneer didn't.
Old Dec 6, 2008 | 12:58 PM
  #100
one of the leads on the wire harnessis fedby the backup lamp circuit in the ETACS. when the backup lamp lights, so does the camera.
