Detailed Rear Camera Installation
Old Dec 4, 2012 | 02:36 PM
  #211
Vadimus's Avatar
Originally Posted by MM3Canuck
Wow, I did not think about interference. That bad? Really?
2.4GHz industry standard video transmission. Works perfectly in the middle of nowhere, results in dense urban area may vary
Old Dec 6, 2012 | 06:56 AM
  #212
MM3Canuck's Avatar
Good info, thanks
Old Jan 26, 2013 | 03:35 PM
  #213
gotMDX's Avatar
Default alternative combo..
Good info, thanks
I don't have a OE front navi. I like one monitor for both navi and back-up camera. So I just bought a Magellan Roadmate 5265T-LMB gps and a Magellan wireless back-up camera for $300. It will not be as nice and clean as the op but this will be a moderate $$ for what I need. I'm hoping to install it this weekend.....
Whew! It took me almost 3 hours to install because I did not have the proper tools to do the project..duh! Bestbuy was charging me $175 for the install, btw.
The camera's mounted to the license plate. I ran the wire thru the leftside license plate light enclosure and tapped it to the 12v reverse light wire. Mounted and tucked the wireless transmitter inside the tailgate frame.
Next I ran the gps and the receiver 12v line thru the dashboard compartment. I have to dismount the top cover and stereo unit to do this. Overall I am satisfied with the outcome.
I am thinking of enclosing the whole thing so it will only show the face of the gps. Any ideas on what materials to use that's easy to work with?
Attached Thumbnails  Detailed Rear Camera Installation-gps-b.jpg    Detailed Rear Camera Installation-gps-c.jpg    Detailed Rear Camera Installation-gps-.jpg
Old May 17, 2013 | 10:24 PM
  #214
javiermb's Avatar
Thanks for a great post!
Unfortunately I'm not able to see the complete Part 3 of the post or any other parts after it. Anyone knows why?
Also, I have the AUX rca inputs in the center console, are those going to the same connector on the MMCS? If I cut the five wires, would I still be able to use the AUX input?
Thanks
Old Aug 22, 2013 | 10:34 PM
  #215
sakuraart's Avatar
Originally Posted by rdenis
Not a dumb question at all - the brain is only unique to the Pioneer camera (you see the camera is so smart it even hasits ownbrain - j/k). You can buy any camera that has a regular video feed and that will work fine, but let me just comment the following:
I have no tie or affiliation with Pioneer but without a doubt this is one of the best if not the BEST cameras out there. I have looked at a tonne of different camera systems - everything from the eBay specials at $50 to factory Honda, Toyota, GM, and Chrylser systems which go upwards of $500 to $600. The eBay specials typically are not wide angle and even when claiming so max out at about 100 degrees viewing angle. The factory systems which typically have wider viewing angles up to rround a true 120 degrees often have issues with low light and bright light conditions.
This Pioneer kit is a full 130 degrees and operates in the lowest levels of light and brightest daylight without issue. The best part is you can buy it for less than $200 and I guarantee you would not be happier. If you want to replicate (actually exceed) the factory system Mitsubishi offers in Japan then buy the Pioneer system - you will not regret it.
But as I said any old videosystem will work. Hell I even had my system playing Ms. Pacman when I was testing prior to getting the Pioneer camera with the "brain".
I am connecting one of these cameras right now in my 2001 Montero LTD. Took me two days so far connecting the head unit (the 7500DVD from Pioneer). Lots of cables and wires. Very nice sound, the rear cam has a dedicated RCA to the head unit. I can't wait to put it in. Although the head unit has a cable to connect to the reverse wire on the tranny, I am not going to connect it. I'm tired of splicing wires. It will be able to be viewed via a touch on the screen, at anytime while driving. So, if the dip behind you at a light is getting stupid, you can view from the cam too. I'll post how it was installed if anybody wants to know.
Old Sep 17, 2013 | 01:39 AM
  #216
Bzadude's Avatar
On the 2012 ASX the reverse signal wire is a pink wire on the smallest connector. New pioneer GPS and camera now work a treat.
Old Nov 10, 2013 | 08:38 AM
  #217
pbuzz5's Avatar
Default Mini USB
Hi have an UK 07 Outlander Elegance with factory camera and touch screen, the camera has packed up and when put in reverse it is only a green screen with the distance lines on it. Took the trim off inside the boot lid and found a mini usb connector, would this be for the camera as the one i bought to replace it has an RGA jack?
Old Dec 3, 2013 | 01:34 PM
  #218
Vadimus's Avatar
Attached new camera to MMCS.
The camera itself is kinda unique design, cube attached to adapter unlike previous unibody style.
Old one:
Parking radar overlay does not look that good on a bigger screen(comparing to previous 4.3" mirror display screen).
Old Dec 9, 2013 | 07:40 AM
  #219
pbuzz5's Avatar
Sorry didn't explain very well, should my new camera connect to the existing loom with a mini usb? as the camera i brought to replace has a yellow rga jack.
Old Dec 9, 2013 | 07:57 AM
  #220
Vadimus's Avatar
There's no miniUSB on a stock harness.
