Drivetrain shudder / vibration at certain speed
Old Oct 13, 2014 | 11:08 AM
Wheeldog's Avatar
Default Drivetrain shudder / vibration at certain speed
I have an 08 Outlander with the V6 engine that has about 95,000 miles. For a few months now I notice a vibration when I'm at low speed and accelerating. I can sense it through the steering wheel and in the whole vehicle - it isn't too bad but definitely noticeable.
I'm pretty sure it isn't a wheel or tire issue, since it only happens accelerating and seems to happen at a certain engine speed (around 2000 RPM). Also, it happens when driving in a straight line, no turning involved.
I wonder about the harmonic balancer being on the way out, but I don't hear about these things failing much.
Has anyone else been through this or have some ideas about the possible sources?
Thanks.
Old Mar 9, 2022 | 02:35 PM
07xlsguy's Avatar
I know I'm reviving this thread after many years, but did you ever find an answer to the vibration problem you were having? I'm having the same issues and have no clue what it could be
Old Mar 12, 2022 | 11:36 AM
lobuc's Avatar
If transmission fluid is due for a change then get that done if not and you have the v6 then add some lubeguard to it. I believe it's the black bottle, high friction modifier is what you want.
Old Mar 13, 2022 | 07:55 AM
07xlsguy's Avatar
Thanks. Is it certain that it's safe to mix with J2 fluid?
Old Mar 13, 2022 | 12:36 PM
lobuc's Avatar
I was wrong thanks for questioning. The hfm black bottle is for the older models. For the 07 6speed auto it would be the platinum(grey) bottle you can also use the small 2 or 3 oz tube of shudder fix.
Old Mar 13, 2022 | 01:48 PM
07xlsguy's Avatar
Thanks. Have you ever used it before , and did it work? By chance if you did use it, was it in The mitsubishi V6 transmission?
Old Mar 13, 2022 | 02:10 PM
lobuc's Avatar
Yes I have used on a number of vehicles with almost immediate positive results all makes, v6 mitsubishi and hyundai with the mitsubishi transmission not the jatco(nissan) that you have.
Old Mar 13, 2022 | 02:44 PM
07xlsguy's Avatar
Thanks. Much appreciated.
Old Mar 17, 2022 | 05:13 PM
07xlsguy's Avatar
After more troubleshooting, I found that the vibration only exists when the vehicle is switched into switched in to 4 wheel drive or all wheel drive.. It doesn't vibrate in front wheel Drive mode. I'm assuming it could be the drive shaft.. Wondering if there could be anything else, and if it is a drive shaft, is it That bad of a job to replace it? It doesn't really look that involved
rlf14
Jan 19, 2017 04:54 PM
n0c7
Apr 30, 2013 09:19 AM
Russk1978
Nov 23, 2010 11:45 AM
oh_what_up
Jan 11, 2009 09:18 AM
athlete1012
Aug 19, 2008 06:45 PM
