DRL to replace Fog kit?
Old Dec 10, 2008 | 05:41 PM
  #61
tdford's Avatar
Default RE: DRL to replace Fog kit?
ORIGINAL: mitsupartsman.com
rcpax,
i've done a little researchon the photo sensor that's in your Outie. it appears that it sends its signal to the A/C ECU for the auto air feature only. it is not wired to the ETACS.
mitsupartsman, I dont want to mess with the auto function.... its not a big deal to me. But if I order the new switch (stalk) will it have it or no?
PS: CAN NOT add the switch or relay to the shopping cart to order from you site. It keeps asking me to make a Option from the List....
http://www.trademotion.com/partlocat...mp;startrow=11
Old Dec 11, 2008 | 08:49 AM
  #62
mightyOUTTIE's Avatar
just ordered the kit! ^^ can't wait to install them
Old Dec 11, 2008 | 11:34 AM
  #63
mitsupartsman.com's Avatar
switch part number 8614A064 is without the auto function.
btw i removed the option off the part listing it should work fine now
thanks a million for all of your support guys it is much appreciated
Old Dec 11, 2008 | 01:40 PM
  #64
how do I remove the cover by the steering wheel in order to remove and install the stalk? Is there a simple diagram availble?
Old Dec 11, 2008 | 03:16 PM
  #65
jsrd's Avatar
mightyOUTTIE, look here (https://mitsubishiforum.com/m_239989/tm.htm), maybe it can be of aid. Or:
Old Dec 11, 2008 | 05:23 PM
  #66
so there are 2 screws and clips? Do I have to open up the vents too? seems complicated
Old Dec 13, 2008 | 01:35 PM
  #67
jsrd's Avatar
ORIGINAL: jsrd
jsrd is looking into the sensor, it is the same as the rain detection.
i've got to go out of town today, i will dig deeper tomorrow.
Hi mitsupartsman. The investigation that I did is that autoclimate sensor is the same who the Autolight sensor. In the following link I put the information about this (https://mitsubishiforum.com/m_237280/mpage_4/tm.htm). Only I need to check if the C-05 sensor has the 5 terminals and if it is the ready prewiring for autolight function. We must sure with respect to if autolight sensor is now in rain sensor, but I believe that it continues in C-05. . .
mitsuparstman is right, the photosensor is inside the rain sensor in 2009 models in Mexico; in the versions without the rain sensor, the photosensor is in the upper the dashboard...
Old Dec 13, 2008 | 03:44 PM
  #68
rcpax's Avatar
Hi jsrd, but will the 07 dashboard photosensor work with autolights you think?
Old Dec 13, 2008 | 08:12 PM
  #69
jsrd's Avatar
Hi rcpax. I will try to directly check in the photosensor the next monday; otherwise, it would be necessary to replace it by that it comments mitsupartsman, and also it is necessary to check that the MMCS support the autolight function. . .
Old Dec 19, 2008 | 02:40 PM
  #70
ekkkkk...
