Old Jan 5, 2009 | 11:54 AM
  #631
brian360's Avatar
Default RE: DVD in motion patch for NR261UM
ORIGINAL: rnapro
The result is the same. Checking CD displays and then nothing. I thought maybe I am not waiting long enough and let the CD sit in there while I drove around the city on business. I have downloaded as much as I could and tried so many different things.
It appears you've got the same version as I. Not sure what the issue is. According to my records, the md5 of the "loading.kwi" file and "alldata.kwi" for the dvd-in-motion patched version should be:
LOADING.KWI 4397d9fce192254d4788d67fe632e08d
ALLDATA.KWI 466a0f8302bb1f9aa23df4ad87a451c6
Check the md5 sum of the files you've tried. If they match, surely you have the correct software. All you need are those two files on a CD-R or CD-RW. The version up confirmation screen should come up within just a few seconds after "Check Disk".
Failing that, you'll probably have to pull the hard drive, unlock it, and copy the files over manually.
Good luck!
Old Jan 5, 2009 | 12:08 PM
  #632
rnapro's Avatar
Thank you for the quick reply. Now I get to look like I really don't know what I am doing. How do I check the md5 sum of the files?
Old Jan 5, 2009 | 12:11 PM
  #633
brian360's Avatar
ORIGINAL: rnapro
I've never used it myself, but assuming you're using Windows, a quick search turned up this tool "digestIT": http://www.kennethballard.com/module...wSummary&pid=2
Old Jan 5, 2009 | 12:24 PM
  #634
rnapro's Avatar
OK I have figured out how to do the check sum and have found the files that match and will give it a try. Thank you again for the help. If it works Ill send you some Beer Money. :-)
Old Jan 5, 2009 | 01:02 PM
  #635
tdford's Avatar
ORIGINAL: rnapro
1. I burned and image with the ISO file
2. I have made a data CD with the LOADING.KWI and ALLDATA.KWI files.
Just to verify.... you are burning on a CD-R and burning as a IMAGE correct? You do not burn it like a data disc, but as a IMAGE.
Old Jan 5, 2009 | 08:25 PM
  #636
rnapro's Avatar
OK - I did more digging with this check sum stuff and I can not locate the loading.kwi file that matches
Old Jan 7, 2009 | 08:09 PM
  #637
magz's Avatar
Hello guys,
This is great work by everyone here.
Here is my problem
I have the Outlander 2005 with Japanese version of MMSC.
Loader BLD-NR-261JM 2.01
Application 00.00.46
Screenshot in att.
But jap. is not my native language.
Do you have any ideas how to upgrade it to English version?
Thanks.
Old Jan 10, 2009 | 05:03 PM
  #638
turbod27a's Avatar
hey guys
i have um with 30.99 version is there any updates for the patch
thanks for your time
Old Jan 15, 2009 | 08:07 PM
  #639
speedfreak's Avatar
ORIGINAL: Otaku
The Generic patcher is complete : this means that _whatever_ version you have, DVD-in-motion is now available.
Or will be, when I finish the subsystem to my satisfaction.
Woohoo! Go Otaku!
I ran the Outlander Update CD, NR261-UM, Software version Version 00.30.94, DVD in motion allowed ISO on my 2961UM/1.09/30.94 and it works like a champ. Your the man! It was installed on a 2008 Lancer Evolution MR purchased this week. Chimay donation incoming!
Couple of things:
1) Someone told you about the annoying nag screen, but they didn't mention it happens only for the Nav function. If you pop in a DVD or were on the Music Server, you will not see it until you hit Nav. Also, that screen has a language selection menu that I think can be supressed by selecting a language in another menu. Let me know if you need more on that.
2) I saw some complaints about a newer SW version and some requests for updated files... did anyone get them to you? If you like I can hit up my dealer and get you the disk, or rip the new version from my drive if they install it for me. I'm not inclined to do it unless you ask, since I would hate to go weeks without watching movies in traffic like an idiot.
Old Jan 17, 2009 | 11:11 AM
  #640
nhpepe's Avatar
ORIGINAL: speedfreak
ORIGINAL: Otaku
Woohoo! Go Otaku!
Couple of things:
Can you link this latest update ISO? I'm having a hard time finding it. I have version 30.94 and it sounds like this will work!! Otaku, donation incoming because you're than man!
